| My turbo project https://slantsix.org/forum/viewtopic.php?t=14307 |
| Author: | Matadem [ Thu Sep 08, 2005 4:51 pm ] |
| Post subject: | My turbo project |
Just came sunday from Orlando ...also got myself a better paying job ![]() ![]() This week ill install the schnieder cam with my edel 500 for the turbo project Ill be using the holley 350 I am looking for the right turbo ...also got a small intercooler for $17 also I going to get a zeitronix wideband |
| Author: | Rob64GT [ Thu Sep 08, 2005 7:19 pm ] |
Here's a place where you can plot your engine on a turbos compressor map. http://www.turbofast.com.au/javacalc.html |
| Author: | moparlover92 [ Sat Sep 17, 2005 3:22 pm ] |
what mods did you make to your engine for the turbo? Do you have a super six or hyper pak setup? where are you locating the turbo? are you using an intercooler? thanks for any help. |
| Author: | Matadem [ Sat Sep 17, 2005 5:30 pm ] |
The engine in my car is stock with shaved head and Os valves intake is a 4bbl weiand with an edelbrock 500 when I am ready for the turbo stuff December hopefully, i'll just swap the head with a stock head and valves, only ported and a 244 cam using the stock exhaust also carb will be a holley 350 2bbl I will be just experimenting with this to hopefully make it work right and only then I will go bigger... for turbo I think I will get a nissan 300zx turbo....however it might be a little small I am looking at ebay every dayfor turbo's I might get a good deal.... If you want good info go to www.fordsix.com <-- there are 2 setups here that will definitly will work on a slant 6 www.turbomustangs.com <-- here you will get more info than you could ever read for books I got myself 21st century turbo available at www.gatorsuperchargers.com also allot of info available at their yahoo groups super tuning and modifying holley carburators and Turbochargers for now I am just playing with my n/a engine trying to make it work right |
| Author: | Matadem [ Sat Mar 25, 2006 4:38 pm ] |
turbo project coming slowly ![]() ![]() traded the bov I got on ebay for a hks one I finnally bought a turbo (on it's way) a new one a holset h1c with a 12cm exhaust which is similar to a hx35 exhaust time to start modifying the exhaust manifold |
| Author: | kesteb [ Sat Mar 25, 2006 7:15 pm ] |
I personally think you should stop listening to the Fordsix guys and use the Edelbrock. The only reason they are using the 350 Holley is because their intergal log intakes can't use anything else. You are not limited by that little problem. If I remeber rightly, there is an excellent articule on turbomustangs on how to setup the Carter AFB/Edelbrock carburators for blow-thru turbocharging. |
| Author: | Matadem [ Sat Mar 25, 2006 9:18 pm ] |
not to worry because I also got myself a few more edel jets and a marine pump as suggested in the turbomustang article.... I am going to try the holley first then the edelbrock |
| Author: | Matadem [ Fri Apr 21, 2006 7:37 pm ] |
my new toy ![]() |
| Author: | VG-265 [ Fri Apr 21, 2006 9:52 pm ] |
What model Holset is that? |
| Author: | Matt Cramer [ Sat Apr 22, 2006 3:18 am ] |
Cool, are you going blow-through or draw-through? |
| Author: | Doctor Dodge [ Mon Apr 24, 2006 11:14 pm ] |
Here is a look at the draw thru set-up I am working on. DD
| Author: | Matadem [ Tue Apr 25, 2006 6:03 pm ] |
very nice Doc That was my plan in the first place draw thru setup with a buick turbo but now I am going blow thru any of you guys may know if I will get better fuel distribution in boosted conditions If I mod my intake like this?rotate the carb 90 degrees ![]() Thanks |
| Author: | grthigpen [ Tue Apr 25, 2006 7:33 pm ] |
the draw thru has some basic engineering flaws....they do have a tendency to ice up below 50 F ambient. also you can quickly over-carb a draw thru, with a draw thru, you are actually carburating each cylinder with the total boosted cfm of the total carb since the intake is actually feeding its full preassure to each cylinder one at a time. you will also have to rejett and also use a bigger excelerator pump. finally, with a draw thru, you need to have the fuel/air mix flow always in a gravity situation, hard to do since the coil of the compressor side requires the mix to go uphill as it travels around the housing so you will have fuel puddling. Truly, the blow thru is the best setup. alot less modifications anld also a lot less issues. grt |
