It is currently Mon Nov 23, 2026 11:21 pm
PostPosted: Sat Sep 10, 2005 4:04 pm
I have a cable type throttle linkage on my D-150 Dodge Truck and I want to hook up the throttle on my Offenhauser 4 bbl manifold. Th end of the cable looks like a little clevis bolt. I will also need the clamp assembly which mounts somewhere. Does someone make the parts I need? The carburetor is a Holley 390 cfm. I hav e the 20-7 part from Holley what else do I need?
Thanks in advance
 Post subject: throttle linkage
PostPosted: Mon Sep 12, 2005 12:42 am
I am not sure if you need that Holley part 20-7(lever extension). But I believe you are looking for a throttle lever stud, part number 510-20-38 or 510-20-37(short). your cable should fit over stud like the stock arrangement. if you need the part to hold the throttle cable, I think you can use the stock setup. Someone else would need to verify this..Jerry
73 Dart 4dr
70 duster
75 VW bug
ex-88 honda rice rocket
ex-70 cuda 383
