It is currently Sun Oct 11, 2026 6:39 pm
 Post subject: gauges
PostPosted: Tue Sep 20, 2005 12:05 pm
Does anyone know where I can find NOS guages that can fit directly into the dash of a 1971 Duster? I have seen such gauges in Chevy magazines that will replace broken stock ones, with cool looking mechanical/electrical gauges.
Don't ever take a fence down until you know why it was put up.
-Robert Frost (1874-1963)
PostPosted: Tue Sep 20, 2005 12:40 pm
I haven't seen any that are direct swaps, only generics that would require custom work. There are places that make generic plates to fit the a body dash, and you drill to suit your needs. I believe these are $100 or so for the blank plate.
Places like Dakota Digital will take your dash and retrofit electronic gauges but its pricey.
PostPosted: Tue Sep 20, 2005 12:42 pm
No such thing, to my knowledge. Your best bet is to have your original gauges restored, mechanically and cosmetically. There are numerous vendors that do so, but it ain't cheap.
VM
PostPosted: Tue Sep 20, 2005 2:10 pm
there are places rebuilding gauges, or you can do what I am doing and just replace the entire cluster with a fresh set, using the gauges that you would actually want to have.
I am in the process of starting my own small business making custom gauge clusters. I won't be supplying the gauges, but I take existing housings and "change" the backing plate to whatever size and configuration of holes the customer wants for gauges. I will also be using multiple colors, so you could get the background in white, black, red, green, etc.
If you are interested let me know.
