1965 motor to a 1979 904
https://slantsix.org/forum/viewtopic.php?t=14428
Author:  demented_greaser [ Mon Sep 19, 2005 12:43 pm ]
Post subject:  1965 motor to a 1979 904
I have a 1979 904 tranny that I want to mate with a 1965 slant 6, is this fine to do?
Author:  VDART [ Mon Sep 19, 2005 5:43 pm ]
Post subject:  later style 904 tranny
you can do it -- but this is not a cheap option
1) your 65 rear crank register is the small one
your 904 has a large style register
2) solution ---machine- crank register or swap to a 68 & later crank
or order a special torque converter with the correct dimensions
3) go to Lou's house he is giving away the tranny you need.
4) someone else will chime in with spec -- but this should give you an idea of what your up against
Author:  Doctor Dodge [ Tue Sep 20, 2005 7:04 am ]
Post subject:  Re: 1965 motor to a 1979 904
This is a combination that does not "bolt together" without some major "re-arranging". As noter, if you use the 66-67 "small input shaft" 904 you can use the 65 engine.
Also be sure you swap the oil pan and pick-up tube off the 79 and onto the replacement engine.
