| 63 D-100 https://slantsix.org/forum/viewtopic.php?t=14459 |
| Author: | michael_k0 [ Wed Sep 21, 2005 4:26 pm ] |
| Post subject: | 63 D-100 |
I recently took on the job of totally restoring a 1963 D-100 truck for a friend and am totally confused about getting the motor out. I have swapped many motors before, but I am having problems with this one. Do I have to pull the trans (standard) with the motor or do they come apart? I have removed all bolts and they will not separate and I cannot get them out together. Also, what is the correct color for thew engine? Any ideas will help. Thanks mike |
| Author: | SlantSixDan [ Wed Sep 21, 2005 5:38 pm ] |
Yes, the engine and trans will separate, though you can also remove them together if you prefer. Could be the clutch plate is stuck to the flywheel surface, if the truck has been sitting a long time. Slant-6 engine color in a '63 D100 is usually yellow (approximately John Deere yellow), some early-production '63s got red. |
| Author: | michael_k0 [ Thu Sep 22, 2005 6:33 am ] |
| Post subject: | D-100 |
Thanks, I did get it out together, there are holes in the crossmember, I just could not find the bolts due to the large amount of grease and dirt from 42 years of use. It took a lot of blood, sweat and bad language to get it out. Thanks again. mike i |
| Author: | Daddiojoe [ Thu Sep 22, 2005 8:55 am ] |
| Post subject: | Welcome Sweptliner! |
Mike-- Be sure to visit the fine folks at www.sweptline.org They'll be happy to share any D100 tips you need. And they're a great bunch of guys besides. Joe |
| Author: | 63gtcv [ Thu Sep 22, 2005 6:37 pm ] |
| Post subject: | language |
Yes, it always helps to be a cunning linguist. |
