It is currently Fri Aug 14, 2026 11:58 pm
 Post subject: Voltage Limiter
PostPosted: Fri Sep 23, 2005 8:56 am
I have a 66 Valiant Wagon and from reading past posts I believe the voltage limiter is bad. The car has been sitting a long time and temp and fuel guages do not work. In the engine comparment, to the right of the voltage regulator is a part that looks like a voltage limiter. It's an RPM 2291438 and has three terminals marked H, B and S. Can anyone confirm what this is?
Thanks for the help.
Brent
PostPosted: Fri Sep 23, 2005 9:19 am
If it is the same as my 66 Barracuda, I believe that is the horn relay.
The voltage limiter is on the back of the dashboard. It's a cylinder about the diameter of a dime and about 1" long with a single wire coming out of one end of it.
If I'm mistaken someone please chime in.
Steve
 Post subject: Good Call!
PostPosted: Fri Sep 23, 2005 10:01 am
You are correct, that stops the horn working.
Thanks for the help!
 Post subject: Found the problem
PostPosted: Fri Sep 23, 2005 11:51 am
I started to remove the instrument panel to get to my voltage limiter and when I removed my ignition switch I noticed a black wire that was not connected to the socket. Soldering the wire back on solved the problem.
I remember a while back the ignition switch was loose. I probably twisted it just enough break that connection. I hope this helps if someone in the future is trying to fix a faulty temp/fuel gauge problem.
PostPosted: Fri Sep 23, 2005 12:47 pm
That's a good example of why we need to troubleshoot before swapping parts! You could have chased that gremlin for miles ....
Good job!
