It is currently Sat Nov 21, 2026 10:19 pm
PostPosted: Wed Sep 28, 2005 5:23 am
I want to install a oil pressure sending unit for my oil pressure gauge along with my oil pressure switch. Does someone make an adapter to hook up both on my oil pump?
bwhitejr
PostPosted: Wed Sep 28, 2005 5:55 am
Yes, Weatherhead makes one... It's called a brass tee fitting, and can be had in any hardware store.
D/W
If it ain't broke, fix it!
PostPosted: Wed Sep 28, 2005 7:38 am
There is also a combination switch/sender unit that'll work. Think it's even a Mopar part. Ebooger wrote about it in one of his "Mopar Action" issues; I'll see if I can prise the P/N out of him.
 Post subject: switch
PostPosted: Wed Sep 28, 2005 7:54 am
i think the one out of a jeep wrangler will work as they have a light and a gauge. the one i did was on a 90. can't remember how the wiring works though...
zedpapa
soon to have 5 gears!!!
PostPosted: Wed Sep 28, 2005 2:54 pm
You can make a tee fitting with all related adapters / Pats from any hardware store. Use teflon tape and tighten it down snug!
GReg
PostPosted: Wed Sep 28, 2005 4:56 pm
Ebooger says "I never actually confirmed that the dual-sender works with the old gauges, but P/N 5233396 is the best shot."
