What perf. starter works with mopar 6 into 1 header??
https://slantsix.org/forum/viewtopic.php?t=14500
Author:  featherduster76 [ Sun Sep 25, 2005 6:33 pm ]
Post subject:  What perf. starter works with mopar 6 into 1 header??
Looking for a higher performance starter that is lighter than stock and will
work with my mopar 6 into 1 header, any suggestions??
Author:  Dart270 [ Mon Sep 26, 2005 7:10 am ]
The mini starter used on late 80s and up vans/trucks works great. Any 3.9V6 or V8 starter will work. Wrecking yard is a good source, or rebuilds from parts store.
Author:  sick6 [ Tue Sep 27, 2005 7:37 pm ]
are the bolt pattern and flywheel teeth pattern are the same as a /6???
Author:  Dart270 [ Tue Sep 27, 2005 8:01 pm ]
Yep. All V8s (BB and SB), 3.9L V6 and Slant starters will interchange.
Author:  sick6 [ Thu Sep 29, 2005 2:01 pm ]
can of worms here, but which is the lightest and most trustworthy?
Author:  emsvitil [ Thu Sep 29, 2005 2:04 pm ]
A handcrank..........................
:twisted:
Author:  sick6 [ Wed Oct 05, 2005 12:06 pm ]
any real responses?
Author:  Dart270 [ Wed Oct 05, 2005 2:06 pm ]
The mini starters I mentioned are pretty much all the same (minor heatshield diffs) and are light and reliable. As with any unit, watch quality if you get a rebuild. I have bought mine new from MP sources and have had no problems. They are better than the factory starters in every way, except the cute noise...
Author:  sick6 [ Sun Oct 09, 2005 4:05 pm ]
how much did it cost you?
Author:  featherduster76 [ Sun Oct 09, 2005 4:43 pm ]
Post subject:  cost
These are either $129.95 or 139.95 from summit racing equipment.
A rebuilt one fom the parts store really isn't much if any bit cheaper.
They weigh a mere 7 pounds vs. the weight of about a 16 or 17 pound
starter if Im not mistaken. I weighed my stock starter and that's about
what I came up with. Thanks again Lou.
Author:  sick6 [ Mon Oct 10, 2005 12:08 pm ]
I havd been using the re-man ones from checker(big wheel rossi at the time) and they were $35, but they only lasted an average of six months when it was a daily driver.
Author:  featherduster76 [ Tue May 02, 2006 3:49 pm ]
Do the mopar performance starters do good for high compression slant's??
Author:  Ron Parker [ Tue May 02, 2006 4:28 pm ]
yep got one on mine for four years it is a MOPAR Performance about the same cost. Just do it Thanks Ron Parker :D See you at the Farm
Hell Hath No Wrath Than A Possum Scorned
Author:  mopar_nocar [ Sun May 21, 2006 3:22 pm ]
they pop up on ebay all the time. i got mine (new) for 79.95....a little less than a year ago. so far, it has cranked a 400, a 360 and my slant.
sb
