driveshaft length for a-904 to 8.75
https://slantsix.org/forum/viewtopic.php?t=14503
Author:  73ScampSSS [ Sun Sep 25, 2005 10:06 pm ]
Post subject:  driveshaft length for a-904 to 8.75
Hi, I went from a 7.25 rear to a 8.75. I was wondering if anyone has done this and knows the correct driveshaft length when coming from an a-904. Also, is the pinion angle something that is built into the housing, or something that is adjusted with shims between the spring perches? I remember seeing something about it, possibly in a topic or a Mopar Muscle article. The rear I have is supposedly out of a 68 Dart so I don't have to change anything to mount it up.
Author:  mcnoople [ Mon Sep 26, 2005 3:08 pm ]
use the search feature please many posts
And yes you will have to change something the u-bolts are different.
Author:  65 dartman [ Mon Sep 26, 2005 4:09 pm ]
Don't forget the shock plates
Author:  sick6 [ Tue Sep 27, 2005 12:10 pm ]
shorten by some where between 1.75 and 2.25. you will find posts supporting each measurement.
