| Engine weight https://slantsix.org/forum/viewtopic.php?t=14522 |
| Author: | olddaddy [ Tue Sep 27, 2005 10:31 am ] |
| Post subject: | Engine weight |
Probably not the first time it's been asked, but what would a 225 slant/6 engine weigh? This would actually be a long block, no intake/exhaust, carb or externals. |
| Author: | Slant6Ram [ Tue Sep 27, 2005 11:04 am ] |
| Post subject: | Round numbers. |
Shipping on a block with crank and pistions only is 325lb Add in the cam, timing set, oil pump, valve train, damper, and head (bare head is about 80 lb) We'll easily hit 450lb dry without the manifolds give or take. Not something you want to lift on your own. |
| Author: | Dart270 [ Tue Sep 27, 2005 4:12 pm ] |
I have weighed almost all the components of a 225 individually - mid 60s-early 70s. Your mileage may vary... crank - 71-76lbs rods/pistons - 20-25lbs block - 165-168lbs head (complete) - 76-80lbs cam - about 10lbs Add in extras like oil pan, valve cover, rocker train, damper, oil pump/pickup, and you're up around 380lbs for a "long blocK." 75-up heads weigh more. Cast crank motors weigh a bit less. Early 60s cranks are as much as 90lbs some have reported. Lou |
| Author: | Slanted Opinion [ Tue Sep 27, 2005 5:14 pm ] |
Here are some Mopar engine weights: http://www.bigblockdart.com/weights/engineweight.shtml |
| Author: | skraecken [ Wed Sep 28, 2005 12:21 pm ] |
Quote: Slant 6 ---------------------------------------------525
True?
273-340 ------------------------------------------- 525 |
| Author: | sandy in BC [ Wed Sep 28, 2005 12:35 pm ] |
I get 425-450 complete except flywheel for a slant. |
