It is currently Sat Jul 18, 2026 6:33 pm
PostPosted: Fri Nov 04, 2005 4:58 pm
Ok, Had my 3.5 centerline auotdrag wheels mounted on my goodyear front runner tires that are size 25x4.5x15. Does anyone have an idea
of how much air pressure is suggested to be run in these????
PostPosted: Fri Nov 04, 2005 5:07 pm
SSRN National Champion
It should be on the side of the tire. I run M/T frontrunners same size and rrun them any where from 25 lbs to 35 lbs according to conditions. Go To Goodyears web site and see if they have a recmonded psi Thanks Ron Parker :D
Hey Has That Thing Got A Bagel Bamboozler In It
 Post subject: Thanks Ron...
PostPosted: Fri Nov 04, 2005 5:31 pm
Thanks for the input Ron. For some odd reason we looked on the
tires and couldn't find reccomended psi anywhere, :shock:
Go figure!
 Post subject: Ok more ?'s!!
PostPosted: Fri Nov 04, 2005 6:01 pm
Are you running the small bolt pattern autodrags on the front with the stock drum brakes?? What type of lug nuts are you using? Or did you just have longer studs installed>>?? thanks :wink:
PostPosted: Sat Nov 05, 2005 11:58 am
Yes small bolt pattern centerline. A tire dealer ordered them and the lug nuts at the same time rnine inch drums i replaced the left hand wheel studs for right hand Thanks Ron Parker
Hey Has That Thing Got A Bagel Bamboozler in it
