Oil Pressure Switch and Oil Pressure Sending Unit?
https://slantsix.org/forum/viewtopic.php?t=14535
Page 1 of 1
Author:  bwhitejr [ Wed Sep 28, 2005 5:23 am ]
Post subject:  Oil Pressure Switch and Oil Pressure Sending Unit?
I want to install a oil pressure sending unit for my oil pressure gauge along with my oil pressure switch. Does someone make an adapter to hook up both on my oil pump?
bwhitejr
Author:  Dennis Weaver [ Wed Sep 28, 2005 5:55 am ]
Yes, Weatherhead makes one... It's called a brass tee fitting, and can be had in any hardware store.
D/W
Author:  SlantSixDan [ Wed Sep 28, 2005 7:38 am ]
There is also a combination switch/sender unit that'll work. Think it's even a Mopar part. Ebooger wrote about it in one of his "Mopar Action" issues; I'll see if I can prise the P/N out of him.
Author:  zedpapa [ Wed Sep 28, 2005 7:54 am ]
Post subject:  switch
i think the one out of a jeep wrangler will work as they have a light and a gauge. the one i did was on a 90. can't remember how the wiring works though...
zedpapa
Author:  Greg Ondayko [ Wed Sep 28, 2005 2:54 pm ]
You can make a tee fitting with all related adapters / Pats from any hardware store. Use teflon tape and tighten it down snug!
GReg
Author:  SlantSixDan [ Wed Sep 28, 2005 4:56 pm ]
Ebooger says "I never actually confirmed that the dual-sender works with the old gauges, but P/N 5233396 is the best shot."
