It is currently Wed Feb 26, 2025 11:18 pm
 Post subject: heater core q
PostPosted: Wed Sep 28, 2005 7:39 pm
Hey there. I'm making a fool outta myself again (my specialty) but I HAVE to ask...
wich one of the hoses is the one that sends water into the core? the one that comes from the head, am I right? the return is the one that plugs on the water pump just above the lower rad hose?
Juan Ignacio Caino
PostPosted: Wed Sep 28, 2005 8:18 pm
I think so, I got mine in the same way you describe.
Uno se confunde no?
Mopar Muscle is well defend by Slant Six!
Valiant Duster 1971
PostPosted: Thu Sep 29, 2005 5:31 am
Uno se confunde no?
lo peor no es la confusión, es el hartazgo de hacer cosas mal... :lol:
Juan Ignacio Caino
PostPosted: Thu Sep 29, 2005 9:22 am
Eso!, pero yo tengo igual mis mangueras, la entrada al Heater Core es desde la cabeza de la maquina y el retorno es a la bomba de agua y todo funciona muy bonito.
Valiant Duster 1971
PostPosted: Thu Sep 29, 2005 9:51 am
Good for you, I think :? :lol:
PostPosted: Thu Sep 29, 2005 11:38 am
We ain't talkin bout no sisters... :lol: :mrgreen:
Juan Ignacio Caino
PostPosted: Thu Sep 29, 2005 11:48 am
Uh yeah sure :wink:
PostPosted: Fri Sep 30, 2005 12:41 pm
My replacement heater core had two different sized inlet/outlet, so it
was obvious.
Jerry
PostPosted: Fri Sep 30, 2005 8:58 pm
And how they are connected?, the problem here is the inlet/outlet is the same size.
Valiant Duster 1971
PostPosted: Fri Sep 30, 2005 9:31 pm
Same here... while we had some factory improvements such as OEM electronic ignition kinda before the US market, we got stucked on the progress of our beloved slants. Never got the revsited combustion chamber head, nor the 5 plugs block, etc. On the other hand we got the dart GT '65 with factory installed dual 1 barrel carbs...
As far as for heater core is concerned, both connections has always been the same size... does it makes any diffrence to the heater core itself? I mean, as long as you're cutting the water inlet to the core, it will remain cool (kinda) am I rigth? I started this topic cuz when I assembled the whole car I made a mistake and connected the sender hose straight to the core and the return hose to the cut off valvle wich is cleverly positioned on the engine bay, wich made it close the outlet of the heater core with its consequent pressure build up inside the core and subsequent leaks... :mad:
Juan Ignacio Caino
PostPosted: Sat Oct 01, 2005 10:18 am
I believe the a body heater control airflow, not water? :?
I think water is always flowing thru the heater core...
But the air is directed "around" the core, when you want cool air?
My 67 doesn´t have a water valve of any kind, and not the 80 aspen either. :?
PostPosted: Sat Oct 01, 2005 7:06 pm
see? local adaptation. I have a water valvle that closes the water inlet (if you're not a moron like me and connect the hoses wrong way) when you slide the lower lever all to the driver's side.
Juan Ignacio Caino
PostPosted: Sat Oct 01, 2005 8:13 pm
Ok, here is how I got my hoses connected and everything works fine, also my Heater Core is Mopar original part.
http://www.geocities.com/valkirye.rm/Va ... otor-5.JPG
http://www.geocities.com/valkirye.rm/Va ... otor-6.JPG
Haaa!!!.....the old times, before the two alternators and the destructive sound sistem....
Valiant Duster 1971
Users browsing this forum: Bing [Bot], Google [Bot] and 11 guests
