It is currently Wed Feb 26, 2025 2:52 am
PostPosted: Wed Sep 28, 2005 7:41 pm
Since I haven't found online how to decode my VIN, I'm writing it down for anyone who might need it in the future.
From Service manual #WM4671
Model: no. of cylinders displacement
AV1, AL1................6.............................................170.0 Cu.In.
6 225.0 Cu.In.*
AV2, AL2................8.............................................273.0 Cu.In.
AP1, AD1...............6..............................................225.0 Cu.In.
AP2 AD2................8.............................................318.0 Cu.In.
8 383.0 Cu.In.*
8 413.0 Cu.In.*
AC1.......................8.............................................361.0 Cu.In.
8 383.0 Cu.In.*
AC2.......................8.............................................383.0 Cu.In.
AC3, AY1...............8..............................................413.0 Cu.In.
*Extra Equipment
Serial numbers
A new eleven digit serial number supplies all pertinent vehicule information as follow:
First digit -Indicates car makes, model and wheelbase, using the follwing letters:
V...Valiant...short wheelbase W...Dodge...short wheelbase
L...Valiant...long wheelbase D...Dodge...long wheelbase
R...Plymouth...short wheelbase C...Chrysler
P...Plymouth...long wheelbase Y...Imperial
Second digit - Indicates the vehicule price range and number of cylinders, using the following numerals:
1...Low...6 6...Low...8
2...Medium...6 7... Medium...8
3...High...6 8...High...8
4...Premium...6 9...Premium...8
Third digit - Indicates the body style using the following letters:
A...2 dr. Sedan F...4 dr. 2 seat Sub.
B...2 dr,. Hardtop G...4 dr. 3 seat Sub.
C...4 dr. Sedan H...4 dr. H.T. 2 seat Sub.
D...4 dr. Hardtop J... 4 dr. H.T. 3 seat Sub.
E...Convertible S...Special
Fourth digit - Indicates the model series using the following numerals:
2...1962 4...1964
3...1963 5...1965
Fifth digit - Indicates the assemble plant, using the following numerals:
1...Plymouth 4...Imperial
2...Dodge 9...Canada
3...Jefferson
Sixth digit through eleventh digit - Indicates the numerical portion of the serial number beginning with number 100,001 and running consecutively regardless of make or model:
Example:
R 3 B 5 9 100147
Plymouth High line 2 door "A" Canada 147th unit
Short 6 cyl Hardtop Series Built
The above numbering system requires that complete and accurate serial number information be supplied when reffering to a specific car model.
In the example, I think the #5 should mean 1965... but anyway that's some good info...
1965 Valiant Custom 200, 2dr hardtop, 225ci
1997 Monte Carlo, 3800 supercharged swap
1995 Lumina, 3.4 DOHC swap
