It is currently Wed Feb 26, 2025 10:00 am
 Post subject: window seals
PostPosted: Fri Sep 30, 2005 1:01 am
has anyone ever replaced the seals that cover where the window enters the door?
mine are shot and i have the replacements but i don't know how the seals are anchored into the door.
thank you in (vacuum) advance
God took you away, then brought you back to me.
PostPosted: Fri Sep 30, 2005 8:17 am
I haven't messed with a 70's a body in a few years but I think there are a bunch of philips head screws. It should be fairly obvious if you have the new one in hand. Some of the older stuff just clipped into place. You will almost certainly have to remove the door glass to replace them.
