| Early Vs. Late Model Oil Pans https://slantsix.org/forum/viewtopic.php?t=14567 |
| Author: | Dago Red [ Fri Sep 30, 2005 10:48 pm ] |
| Post subject: | Early Vs. Late Model Oil Pans |
| Author: | Walter Lee Jackson [ Sat Oct 01, 2005 12:36 am ] |
From personal experience, the '63 to '66 A body slant six oil pans are rounded (i.e. curved) and thus avoid touching the k member. The later oil pans are squared, and thus touch the early k member. Just put the early pan on the later engine and you avoid the problem. --Walt Jackson 1963 Dodge Dart GT convertible. |
| Author: | VDART [ Sat Oct 01, 2005 5:13 am ] |
| Post subject: | oil pan |
I've also seen a 1/4" plate under the p/side mout to lift the engine- & made it clear the cross member. Make sure you swap the pick -up tube also |
| Author: | Charrlie_S [ Sat Oct 01, 2005 6:10 am ] |
Actually, the 66 should have the dropped drag link, six or eight. 64-65 had the two different drag links. |
| Author: | Dago Red [ Sat Oct 01, 2005 3:01 pm ] |
| Author: | kesteb [ Tue Oct 04, 2005 8:50 pm ] |
Been there, done this. You can use a F-body oil pan in an early A-body. The pan will rest against the k-member on the right front corner and across the \6 center link. You can fix this by denting the corner in about 1/2", or cutting the corner out and replacing it with new flat piece of sheet metal. The center link problem can be cured by using a v8 center link or by denting the bottom of pan in about 1/8". There is plenty of clearence from the pitman and idler arms. |
