| how do you remove a harmonic balancer https://slantsix.org/forum/viewtopic.php?t=14649 |
| Author: | spamman450 [ Sun Oct 09, 2005 12:01 pm ] |
| Post subject: | how do you remove a harmonic balancer |
i cant figure out how the harmonic balancer comes off. is there a special tool i can buy to do it, or is there some way i can do it with normal tools? if someone could describe a step by step process for removing it i would be very happy. thanks Rory |
| Author: | sandy in BC [ Sun Oct 09, 2005 12:02 pm ] |
You need a damper remover tool. Once you see it you will know how to use it. |
| Author: | '74 Sport [ Mon Oct 10, 2005 6:05 am ] |
I did not have a special tool when I did my son's, so it must have been one of his grandfather's regular ol' steering wheel or pulley puller I dug out of his shop. Jerry |
| Author: | 440_Magnum [ Mon Oct 10, 2005 8:44 am ] |
| Post subject: | Re: how do you remove a harmonic balancer |
Quote: i cant figure out how the harmonic balancer comes off. is there a special tool i can buy to do it, or is there some way i can do it with normal tools?
You can pick up a combo puller (it doubles as a steering-wheel puller) from most part stores for under $20. It'll be cheap chinese-made junk, but it'll pull a balancer a half dozen times or so before turning to a pile of scrap metal if someone could describe a step by step process for removing it i would be very happy. thanks Rory |
| Author: | Tim Keith [ Mon Oct 10, 2005 9:34 pm ] |
Some auto parts stores have tool rental programs, they might have the puller. Check with Autozone and the other parts big retailers. |
