Slant 6 into a 5th Avenue
https://slantsix.org/forum/viewtopic.php?t=14656
Author:  Renown [ Mon Oct 10, 2005 9:29 am ]
Post subject:  Slant 6 into a 5th Avenue
What is the possibility of dropping a Slant 6 into a 1987 Chrysler 5th Avenue. Nothing wrong with the 318 except it's tired and it uses 2 more spark plugs then I'm used to.
Author:  mcnoople [ Tue Oct 11, 2005 6:53 am ]
It would req a k-member change which is prolly a lot more work than it is worth. Of course if you have a good f/m donor car you could leave it bolted to the k and swap the entire suspension/K/engine at the same time. You could just kinda roll the entire assembly in and out. stay with the 318
Author:  Jeb [ Tue Oct 11, 2005 8:34 am ]
I don't think a slant would like the 2.25 gears in the rearend of the fifth ave either.
