| LCA rebuild https://slantsix.org/forum/viewtopic.php?t=14729 |
| Author: | bbbbbb9 [ Tue Oct 18, 2005 6:51 am ] |
| Post subject: | LCA rebuild |
I'm getting a front end bushing set for my 78 Aspen Wagon and for the lcas it says to use the outer shell. But here http://moparmusclemagazine.com/tipstric ... trol_arms/ they say to pull them out. Is it OK to just leave them in and insert the bushing? |
| Author: | relic-lover [ Tue Oct 18, 2005 8:21 am ] |
| Post subject: | P word ? |
Use the instructions that come with the parts you are installing. The manufacturer knows more about the parts than the magazines. Did you order poly or rubber bushings? Generally, when poly bushings are being installed the old shell is not removed and the poly bushing are installed inside the old shell. For rubber bushings both the shell and the bushing are removed and then replaced as a unit. If you ordered poly - don't let DW hear about it |
| Author: | bbbbbb9 [ Tue Oct 18, 2005 8:56 am ] |
Who's DW? Thanks by the way. I know that some say don't use poly in the LCA, but Energy Suspension sells a kit (Botsides upper and lower), and they said don't mix poly and rubber. What's the problem with poly in the LCA? |
| Author: | Bohmer2 [ Tue Oct 18, 2005 9:50 am ] |
D/W = Dennis Weaver... to get Dennis' and lots of other peoples opinions on the poly bushing issue just do a simple search of this site. I won't divulge any of the fun here just look for old posts on front end rebuilts or poly bushings. Brian |
| Author: | bbbbbb9 [ Tue Oct 18, 2005 10:02 am ] |
Thanks, I'll remember all I read when I'm working on the Project. This is just a quicky front end rebuilf so that I can drive my 78 Aspen wagon. for about a year. Got it for $300, it's clean as all get out with the super six and 833OD tranny, which eventually is going into my 64 Dart wagon (or maybe pickup custom). Too many cars. Need to get rid of the 83 Ramcharger I've been driving. Thanks again all |
| Author: | mcnoople [ Tue Oct 18, 2005 10:48 am ] |
poly can also be spelled "creeeeeeeeeak" or "groan" |
| Author: | slantvaliant [ Tue Oct 18, 2005 12:32 pm ] |
How does the Aspen/Volare LCA differ from the A-body LCA? |
| Author: | slantvaliant [ Tue Oct 18, 2005 12:40 pm ] |
Oops. Double post |
| Author: | Dago Red [ Tue Oct 18, 2005 7:01 pm ] |
