It is currently Mon Nov 16, 2026 8:02 pm
PostPosted: Tue Oct 18, 2005 7:42 pm
my question is if you set your dist. & the phrase 1 tooth off-- how much in timing degrees is that 1 tooth??
also how many degrees can be adjusted on the slant 6 dist? I'm talking about initial --not any advance included
just the 2 slots that the 7/16" bolt holds tight!!
thanks
PostPosted: Tue Oct 18, 2005 7:55 pm
thanks
count the tooths and divide 360 by that number. That's the amount of degrees that you offset by offsetting a tooth.
Juan Ignacio Caino
PostPosted: Tue Oct 18, 2005 9:03 pm
I believe there are 13 teeth, so 360/13 = 28 degrees per tooth. Keep in mind those are cam degrees, so it would be 56 deg at the crank.
The two slots combined give more than 1 tooth of range, but you might want to advance/retard a tooth to get into a comfortable slot range.
 Post subject: tooth
PostPosted: Tue Oct 18, 2005 9:24 pm
Thanks--
Users browsing this forum: Ahrefs [Bot], Amazon [Bot] and 5 guests
