| Low mount alternator https://slantsix.org/forum/viewtopic.php?t=14739 |
| Author: | andyf [ Tue Oct 18, 2005 2:48 pm ] |
| Post subject: | Low mount alternator |
I designed and built up a set of brackets that allows a person to bolt a 10si type of alternator onto a slant. It uses the driver's side block mount so this won't work if you have PS. I prefer the alternator mounted low on the driver's side since it makes the belt shorter and it provides for a short charge cable to the batt. The 10si alternator is very inexpensive since they came on many GM cars for many years.
| Author: | SlantSixDan [ Tue Oct 18, 2005 3:12 pm ] |
Now that's a nice, clean setup that approximates the factory '60 passenger car and '60s A100 van setup. That particular GM alternator was indeed used from '72 through the early '90s. It probably would not be my first choice if I could pick any alternator to use, but it's certainly cheap and widely available, and I can't imagine it'd be too hard to adapt the brackets to take whatever other alternator one wanted to use. Would likewise probably not be too hard to come up with a "highboy" version of this bracket that would sandwich over the water outlet ('60 passcars with P/S had a special water outlet P/N 2121908 with cast-in alternator pivot). This is a one-off deal you made for your own use? Or something you're going into production with? |
| Author: | james longhurst [ Tue Oct 18, 2005 5:31 pm ] |
gee, looks like lou's V. -james |
| Author: | andyf [ Tue Oct 18, 2005 8:02 pm ] |
Dan, I built this kit for a guy in CA who wanted it and I built a few more while I was at it just in case anyone else wanted them. They are fairly inexpensive kits since it is just a bracket, a strap, a bolt and a spacer. I used the GM 10si alternator since it is a very well designed alternator and is easy to find in any autoparts store anywhere. I did a similiar kit a few years ago for a race guy but in that case I used a small toyota alternator. I prefer the Toyota alternator (made by Denso) since it is smaller and lighter, but they are quite expensive to purchase new. The 10si alternator is internally regulated so you can get rid of the external regulator at the firewall. Since the alternator is so close to the battery you can hook the out put straight to the Batt (or the hot side of the starter relay) and you can hook the voltage reference of the alternator to the same place. So the wiring is pretty simple. Just take the wire that was going to the old regulator and extend it to the alternator and you're about done. Mark Hamilton at MAD sells a nice 10si wiring kit that would make the whole exercise a cake walk. www.madelectrical.com is his website. |
| Author: | andyf [ Tue Oct 18, 2005 8:25 pm ] |
Here is a picture from the rear. I added a small tab to the bottom of the bracket so people would still have a place to bolt the negative cable from the battery to.
| Author: | SlantSixDan [ Wed Oct 19, 2005 8:37 am ] |
Quote: I used the GM 10si alternator since it is a very well designed alternator
I donno if I'd go quite that far. It's certainly adequate, and if built carefully using quality parts it's reasonably dependable. But, like you, I would prefer the smaller and lighter (and more durable) Nippondenso alternator, as used on '89-up Mopars and many other cars. Quote: The 10si alternator is internally regulated so you can get rid of the external regulator at the firewall.
I view this as one of the major disadvantages of the GM alternator, not an advantage. Those internal regulators aren't as durable or dependable as most of the external types we're familiar with—one still sees GM vehicles with flickery/pulsating exterior lights—and if the regulator fails, there's no such a thing as you flip open the hood, toss a new regulator on the firewall, and drive off. Instead, it's either an alternator swap or an afternoon spent pulling the alternator all apart. Quote: MAD sells a nice 10si wiring kit that would make the whole exercise a cake walk. www.madelectrical.com
Yeah, I've commented in this forum before on some of the screwy ideas and half-baked fixes found on that site.
| Author: | 440_Magnum [ Wed Oct 19, 2005 10:01 am ] |
Just my opinion, but that's a huge strike against it for me. I prefer external regulators- the ones inside alternators are subject to all the heat and abuse of being where they are, and they fail. Firewall regulators (electronic ones anyway) just about NEVER fail. Also if you hook it up as a "one-wire" setup without an ignition sense wire, you've got to rev the snot out of it to get it to kick in after its been sitting. The place I work has an old Federal cherry-picker type crane (powered by a Chrysler industrial flathead six through fluid drive, I might add My favorite alternator, bar none, is the Chrysler 100A unit- the things are indestructable. But its big and bulky and getting hard to find. For a compact alternative, I'd go with a Denso off a 90s Dodge truck (or any other Mopar, but the trucks through '91 or so still had the twin-groove V-belt pulley and not a serpentine). Not to detract from your setup at all- thats a VERY nice bracket set and very professionally done! |
| Author: | Dennis Weaver [ Wed Oct 19, 2005 1:15 pm ] |
Quote: Firewall regulators (electronic ones anyway) just about NEVER fail.
...coulda fooled me!D/W |
| Author: | 440_Magnum [ Fri Oct 21, 2005 11:25 am ] |
Quote: Quote: Firewall regulators (electronic ones anyway) just about NEVER fail.
| Author: | mpgFanatic [ Sat Nov 05, 2005 7:03 pm ] |
| Post subject: | They smell pretty potent when they fail. |
Quote: Quote: Quote: Firewall regulators (electronic ones anyway) just about NEVER fail.
...coulda fooled me!When I told that story to the Early Valiant Barracuda Club, I saw another guy respond, "Yea, me too." We compared notes, found we had purchased at roughly the same time, from the same vendor. I hope they have a different supplier by now, but I suppose I ought to check before broadcasting slander. Haven't had the time to follow up. I have since added an inliine fuse to the input terminal wire, although perhaps a fusible link would be less perceptible. Either way, now that I've seen what can happen, I wouldn't run that car without it. My guess is that the original mechanical units, despite their propensity to wear out after 20 or 30 years, didn't suffer from build quality problems so there was no need to include a fused circuit. - Erik |
| Author: | 440_Magnum [ Mon Nov 07, 2005 12:51 pm ] |
| Post subject: | Re: They smell pretty potent when they fail. |
Chalk up another failure, here. I bought one that looks like the old mechanical type but is electronic inside. It lasted a year or so. When it failed, it took half the wiring harness with it. Thank God I simultaneously smelled acrid smoke and noticed the engine wasn't running right, glanced down at the gauges and saw NO ammeter needle (turns out it was pegged out of sight) so frantically killed ignition, lights, switches, anything I could turn off because I didn't know where the short was. Upon later disassembly, I discovered the firewall regulator had shorted its input terminal to ground, thanks to a shoddy rivet holding the terminal to the circuit board.
Well, I've had mechanical ones fail *exactly* that way- the contacts weld closed and the alternator goes full-field, but on the couple of times I've had an electronic one fail its always failed "no charge."When I told that story to the Early Valiant Barracuda Club, I saw another guy respond, "Yea, me too." We compared notes, found we had purchased at roughly the same time, from the same vendor. I hope they have a different supplier by now, but I suppose I ought to check before broadcasting slander. Haven't had the time to follow up. I have since added an inliine fuse to the input terminal wire, although perhaps a fusible link would be less perceptible. Either way, now that I've seen what can happen, I wouldn't run that car without it. My guess is that the original mechanical units, despite their propensity to wear out after 20 or 30 years, didn't suffer from build quality problems so there was no need to include a fused circuit. - Erik The worst charging system failure I ever had was an alternator rotor that grounded itself internally, giving a full charge *and* drawing a huge rotor current and melting the wire to the field terminal (dual field terminal system). The sad truth is that build quality on all sorts of components is going into the crapper lately and you've got to be REALLY careful what kind of parts you buy. Dan Stern has P/Ns that he always recommends for both the new-style (dual field terminal) and old-style electronic replacement regulators, and they've always done right by me. I don't have 'em with me right now, though. |
| Author: | emsvitil [ Mon Nov 07, 2005 1:20 pm ] |
Quote: The worst charging system failure I ever had was an alternator rotor that grounded itself internally, giving a full charge *and* drawing a huge rotor current and melting the wire to the field terminal (dual field terminal system). How about you're going to San Diego (from Huntington Beach) to fix your sisters alternator and as you get off the fwy in San Diego your car dies and wont start.... Then you have a terrible time trying to get ahold of your sister (to come and get you) because her phone line is constantly busy (seems she's calling my parents wondering where I am). So she tracks down one of her friends to rescue the rescuer.... They finally show up and I decide to push start my car. The car starts and there's immediatelly smoke. The alternator has shorted internally because the bearings went south (which is why it died originally), and to top it off it jams up and the belt breaks (which also runs the water pump). So you decide to pull the electrical connections to the alternator and run on the battery to her house. Car starts this time without a push start since there isn't any electrical drain of a shorted alternator, but you only go about a block before it overheats (alternator and water pump had same belt). So now you disconnect the AC belt and run it around the alternator and use the idler pulley (with vice-grips to hold the idler pulley in the correct location since the belt was never designed to do what you're doing) to get a cooling system. Now you manage to get your car running and get to her house............ Now the fun begins......... Remove all the alternators and then figure out what's wrong (mine's obvious) and hers has worn out brushes. Get taxied to the auto parts store by her friend for replacements.... Hers simple, mine; well............. what kind of car is that for??????? Well, it's a GM alternator but it's on a mazda....... Bring some out so we can match it......... The closest comes out to be something for a 73 Chevy or something like that, but I have to rotate the back end to make it work........ Then there was the time her car wouldn't start and I went down there and the problem was.......... ready????? believe it or not.. It was in drive........ (which is really really out of character for her since she's normally somewhat mechanically inclined........) |
