| Need some engine specs https://slantsix.org/forum/viewtopic.php?t=14740 |
| Author: | 1966 dart wagon [ Tue Oct 18, 2005 3:49 pm ] |
| Post subject: | Need some engine specs |
ok i have a 1966 dart wagon with a 1975 slant six in it, i swaped intake/exhaust manifolds cause the exhaust was cracked. as i find out later its good i replaced the egr manifold. Later on after all the work i put into getting my wagon looking good(carpet, lots of rubbing compound,engine swap, clutch) i get into an accident ok back to the motor i was gonna fix up the 75 slant but i have an extra motor in my back yard that is dated: 11 19 63 2463430-7 it has 3 frost plugs on the intake/exhaust side(this is different than the 75 motor) it has round holes for the spark plugs, also i notice it has hydrolic lifters (this motor was orignaly gonna go in my wagon but i found an assembled motor so i used that) so should i build the 1963 block or the 1975 block is one block thinker then the other or anything is the other aluminum i dont think so but you tell me |
| Author: | 1966 dart wagon [ Sun Oct 23, 2005 12:29 pm ] |
anyone......anyone at all |
