1 tooth = how many degrees? on timing advance/retard
https://slantsix.org/forum/viewtopic.php?t=14745
Author:  VDART [ Tue Oct 18, 2005 7:42 pm ]
Post subject:  1 tooth = how many degrees? on timing advance/retard
my question is if you set your dist. & the phrase 1 tooth off-- how much in timing degrees is that 1 tooth??
also how many degrees can be adjusted on the slant 6 dist? I'm talking about initial --not any advance included
just the 2 slots that the 7/16" bolt holds tight!!
thanks
Author:  argentina-slantsixer [ Tue Oct 18, 2005 7:55 pm ]
Post subject:  Re: 1 tooth = how many degrees? on timing advance/retard
thanks
count the tooths and divide 360 by that number. That's the amount of degrees that you offset by offsetting a tooth.
Author:  Dart270 [ Tue Oct 18, 2005 9:03 pm ]
I believe there are 13 teeth, so 360/13 = 28 degrees per tooth. Keep in mind those are cam degrees, so it would be 56 deg at the crank.
The two slots combined give more than 1 tooth of range, but you might want to advance/retard a tooth to get into a comfortable slot range.
Author:  VDART [ Tue Oct 18, 2005 9:24 pm ]
Post subject:  tooth
Thanks--
