plastic pieces in engine
https://slantsix.org/forum/viewtopic.php?t=14757
Author:  spamman450 [ Thu Oct 20, 2005 12:38 am ]
Post subject:  plastic pieces in engine
i installed my harmonic balancer on my slant this weekend by tapping it on with a plastic hammer and a pice of wood. when i looked in the oil pan there where several tiny pieces of plastic that where not there before the install. i asuume i banged them loose from somwhere. any ideas?
Author:  GTS225 [ Thu Oct 20, 2005 3:13 am ]
Take a careful look at your distributor drive gear. Also, did/do you have the cam timing sprocket that has the plastic teeth?
Roger
Author:  Charrlie_S [ Thu Oct 20, 2005 4:39 am ]
Nylon teeth from the cam sprocket?
Author:  spamman450 [ Thu Oct 20, 2005 10:07 am ]
the distributor was not in the motor at the time. is the cam timing sprocket hard to replace?
Author:  slantzilla [ Thu Oct 20, 2005 2:27 pm ]
Well, you start by pulling the balancer off you just put on..... :shock:
