| Steering pin removal https://slantsix.org/forum/viewtopic.php?t=14759 |
| Author: | textoad1 [ Thu Oct 20, 2005 8:02 am ] |
| Post subject: | Steering pin removal |
I have finally given up on my '74 Scamp power steering box and I plan to remove it this weekend. Is the coupling pin tappered? I tried to reove it once before and could not bugde it so I gave up. Now I'm determined. Any hints on getting it out would be appreciated. Thanks. |
| Author: | SlantSixDan [ Thu Oct 20, 2005 9:56 am ] |
After three decades in place, those pins can really be stubborn. It's not tapered; it's just a standard split roll pin that can be driven out with a properly-sized punch and a BFHammer. Applying Kroil or Coca-Cola can help. |
| Author: | CStryker [ Fri Oct 21, 2005 8:35 am ] |
For stuck, rusty parts, I have found PB Blaster to be best thing on the planet. Soak it in it for a while and it should make things go much smoother. |
| Author: | textoad1 [ Fri Oct 21, 2005 3:03 pm ] |
Well I got 'er done. Soaked it with WD40 overnight and she came right out. Got the whole gear reamoved and replaced in less than 3 hours. And flushed and all new fluid. Works great so far. I was having some very strange power steering problems but they seem to be gone. Thanks all. |
| Author: | SlantSixDan [ Fri Oct 21, 2005 3:53 pm ] |
Quote: For stuck, rusty parts, I have found PB Blaster to be best thing on the planet.
Probably 'cause ya never tried Kroil |
| Author: | emsvitil [ Fri Oct 21, 2005 3:57 pm ] |
And I thought you're supposed to use TransX.............. |
| Author: | CStryker [ Fri Oct 21, 2005 4:30 pm ] |
Where does one find this magical kroil stuff in the US? |
| Author: | Charrlie_S [ Fri Oct 21, 2005 5:22 pm ] |
As far as I know, Kroil is only available direct from the manufacturer. Kano Laboratories 1000 S. Thompson LN. Nashville, TN 37211 1-800-311-3374 |
| Author: | relic-lover [ Fri Oct 21, 2005 6:39 pm ] |
| Post subject: | Available from Eastwood also |
The Eastwood Company sells it mail order or on their website. http://www.eastwoodco.com/ just search for Kroil - they have an aerosol and a larger size (half gallon?) |
| Author: | Charrlie_S [ Sat Oct 22, 2005 6:34 am ] |
Much cheaper, here. https://secure.cnchost.com/kanolabs.com ... rial.shtml |
| Author: | slantzilla [ Mon Oct 24, 2005 12:12 pm ] |
We have used Kroil and PB Blaster here at work. They are both exceptional products. |
