paging Doc!! exhaust manifold core question
https://slantsix.org/forum/viewtopic.php?t=14785
Author:  VDART [ Sat Oct 22, 2005 7:17 am ]
Post subject:  paging Doc!! exhaust manifold core question
I have seen more than once about save the broken exhaust for Dutra's for a core?
Is there a core charge for Dutra's? I thought they were a completely new cast unit consisting of a front & back unit?
If you need cores --where can they be sent--- Thanks
Author:  SlantSixDan [ Sat Oct 22, 2005 8:53 am ]
I'll let Doug answer the "where sent" question, but only the front-3 casting is new with Dutra Duals. The rear-3 is a modified (cut 'n' capped) stock manifold.
Author:  VDART [ Sat Oct 22, 2005 9:33 am ]
Post subject:  Dutras
Thanks Dan -
Author:  64ragtop [ Sat Oct 22, 2005 2:27 pm ]
Post subject:  Dutra?
Ok, so I meant I wanted to use a "Dual Dutra" manifold setup when I replied to the hot street motor thread. It just seems like there could be a significant difference in back pressure between the three front cylinders and the back ones. Besides, I live in South Texas, and don't figure I'll need exhaust manifold heat (and the hyper pack intake doesn't have provision for it anyway).
