new MP rear axle bearing set
https://slantsix.org/forum/viewtopic.php?t=14807
Author:  Michael [ Mon Oct 24, 2005 11:28 am ]
Post subject:  new MP rear axle bearing set
Has anyone used the "new" axle bearing kit from MP for their 8 3/4? Is it better than the OEM set-up. It claims to do away with the end play adjustment which I've always found to be a bit of a pain. Is this good for a daily driver? Any thoughts are welcome.
P.S. This kit is pictured on p.297 of the new Summit cat. Thanks Michael
Author:  slantzilla [ Mon Oct 24, 2005 12:10 pm ]
Sounds like a redo of the Green bearing kit. I have run Green bearings on the street for years. :shock:
Author:  Ron Parker [ Tue Oct 25, 2005 7:08 pm ]
Yep thats the deal do it. :D Thanks Ron Parker
Hey Has That Thing Got A Bagel Bamboozler In It
Author:  dusty7t4 [ Tue Oct 25, 2005 7:44 pm ]
either way, pressin bearings is a pain. not as bad as replacing upper control arm bushings, but right up there none the less.
-dave
Author:  guest [ Thu Oct 27, 2005 9:49 am ]
When I got my 8 3/4, it had 1 green bearing and 1 stock. I wanted maximum robustness, so I decided to go to stock on both, but the cover plates had been badly damaged. I could get the bearings and seals anywhere, but the covers were difficult to find and I bought 2 factory kits from Year One.
Each kit has the covers for BOTH sides; you only need one kit to get both covers. That only left he adjustment lock tang; I never found a source for it and got one from scrap axle.
