source for stock electrical connectors
https://slantsix.org/forum/viewtopic.php?t=14821
Author:  sixsignet [ Tue Oct 25, 2005 11:34 am ]
Post subject:  source for stock electrical connectors
Is there a source out there for electrical connectors for early 60s a-bodies?
I need the T-shaped 2-conductor connectors for the single-speed wiper motor. I need the male and female.
Author:  mcnoople [ Tue Oct 25, 2005 1:13 pm ]
If you're not going for resto perfection just use any connector with the correct wire guage. Do you need the terminals or the plastic or both.
Author:  sixsignet [ Sat Oct 29, 2005 9:09 pm ]
I needed the plastic and the terminals.
I found a set on an early 80s Toyota truck near the windshield washer reservoir.
They fit the connectors for the 63 one-speed wiper. I just had to cut off the retaining clip.
I used these connectors to plug my intermittent wiper control
in-between the wiper motor and the original wiring harness.
The T-shaped 2-conductor connectors they sell now have a wider gap between the two conductors and the plastic shell does not match the 63 mopar connector.
Author:  cavisco [ Sun Oct 30, 2005 8:08 am ]
Try waytekwire.com. They carry the packard 56 series connectors and terminals (pg 29 of there catalog) that were used on the old mopars. Next time you are at the pick n pull grab a harness or 2 from a late model crown vic or one of those huge suvs. Lots of good multi-colored wire in those beast and the insulation on the modern wire has a higher temperature rating than the old oem stuff used years ago. Invest in the correct crimp tool and solder each connection after crimping. I built a complete underhood harness for a '66 fury this way. Works great.
Scott.
