It is currently Wed Nov 18, 2026 3:44 am
PostPosted: Mon Oct 24, 2005 1:57 pm
Hello all! This is my first post here, glad I found the place.
I've got a 1966 Plymouth Belvedere I 4-door Sedan. She ain't much, but she's all mine! Due to circumstances beyond my control it has been sitting for a couple of months. I recently went out to start it up and it just won't turn over. It'll sit there and crank all day, just won't get running. I've checked for spark and it's getting spark at the distributor. I've noticed that if I let it crank for a few seconds, when I stop, gas seeps out from the gasket under the carb. So, I'm assuming it's getting gas to the carb (although that leak can't be good!).
Any ideas? With the nice fall weather I've been itching to get my baby back on the road. Thanks in advance.
PostPosted: Mon Oct 24, 2005 8:30 pm
Couple of ideas. Could be your choke is stuck closed from sitting. That would explain the gas seeping from the carb base. Your spark plugs get wet with gas and your ignition does not make enough power to fire them wet. Does the car try to catch at anytime, only to not run when you release the key from the start position? Then it is your ballast resister. Could also be worn coil (just because you have spark, dosn't mean its powerfull enough to ignite fuel). I'm betting on the choke. Try starting the car with the air cleaner off, and a way to keep the choke plate open to get air into it.
PostPosted: Tue Oct 25, 2005 1:39 am
pour some fresh gas into the carb throats w/o air cleaner assy. If she starts, the gas into your carb/lines/tank may be bad, from sitting too long.
Juan Ignacio Caino
PostPosted: Tue Oct 25, 2005 5:04 am
Thanks for the tips! I already tried the fresh gas in the carb trick to no avail. Gonna swap out the ballast resistor and have my son hold the choke plate open. Might even pick up a new coil. Supposed to be a great weekend, getting my toy back on the road would make it even better!
PostPosted: Tue Oct 25, 2005 5:23 am
check your plugs!!
If you have that much fuel seeping from the carb -- most likely your plugs
are now fuel fouled (soaked /wet with fuel)
if they are wet-- your car will not start-- clean & dry them & let the cylinders dry(compressed air helps)--
you will need new plugs shortly-- try to get it running on the fouled ones --then replace
if they are clean then proceed
with other solutions
PostPosted: Tue Oct 25, 2005 6:53 am
I'll add that to the list. Looks like I'll be performing a tune-up this weekend!
PostPosted: Tue Nov 01, 2005 7:01 am
Alright, here's a problem I didn't think I would have. None of the auto parts stores in my area carry any of the parts I need save for the spark plugs. When I asked for a ballast resistor I was met with blank eyes. I didn't even bother to ask about a coil. How late into the 70's/80's were the parts and supplies for the 225's remain unchanged? Maybe this will help with my search for parts. Also, I would greatly appreciate it if someone could give me a link to a decent online source for new slant six parts. It's killing me to see my car sit in front of my house during this wonderful fall weather.
PostPosted: Tue Nov 01, 2005 7:21 am
Lets not throw hard to find parts at it. Take out the plugs ,,,clean them cared fully and gap them. If wet use your Bic lighter to dry them off. Crank the engine over with the plugs out to clear the cylinders. Install the plugs and try again. You can hold the choke open by putting a screw driver (or butter knife for that matter) in the top of the carb to hold the choke open.
If it floods again you need to unstick your carb needle and seat.
When you get it running , think about a valve adjustment.
If you dont have electronic ignition you might start thinking about that as a weekend project.
DONT JUST BUY PARTS unless you are rich.
PostPosted: Tue Nov 01, 2005 9:26 am
Online
Hey, 66 Belv... if it cranks that means it IS turning over.... (2 ways of saying the same thing) it isn't firing. I get that kind of description all the time from people that call me for help on their dead cars. They don't seem to "get" that cranking IS turning over.
PostPosted: Tue Nov 01, 2005 11:37 am
I 'get' it. Was just shooting from the hip with my first post. Desperation can make you sound stupid at times.
Hoping to have time this weekend to try some of the HELPFUL advice I've gotten from the friendly folks here.
Thanks everyone!
PostPosted: Tue Nov 01, 2005 12:52 pm
Online
Hey, sorry if I was a little "harsh" in my last post... got something on my mind... (not happy thoughts either) Got 2 tickets Sunday (1 speeding the other because my new insurance card was in my billbox instead of my Jeep... been to the cop shop twice now to rectify the insurance one. They marked it as a "MUST appear in Court" and I am scheduled to work that day... Normally the speeding one would be a mail in deal.... nowe I gotta miss a days work (and $300 ) my place don't go for "being a little late"... either you're there or your not, so itll cost me a days pay to go show em my card and have the ticket dropped... I'm trying to satisfy them when I have the time ... convenient for ME to avoid that!
PostPosted: Tue Nov 01, 2005 2:58 pm
Hey no problem. Not having the best day/week/month here either.
Best of luck with the ticket and thanks for the reply. Seems civilty can be in short supply these days. Refreshing to see it now and again.
PostPosted: Tue Nov 01, 2005 5:24 pm
update!! how were the plugs???
PostPosted: Wed Nov 02, 2005 5:27 am
I got so discouraged trying to find parts that I never even opened the hood. Going to take a shot at it this weekend. Been pulling long hours at work lately, getting home long after dark. Feel like a zombie.
PostPosted: Wed Nov 02, 2005 6:07 am
Like others have said -- check some items out first (THE PLUGS)-- then you can buy your parts--
online use (rockauto.com), partsamerica.com & all the other fast-type parts stores have online service
Users browsing this forum: Amazon [Bot] and 5 guests
