It is currently Tue Nov 17, 2026 1:28 pm
PostPosted: Fri Oct 28, 2005 9:46 am
I am a newbie starting to work on a '60 /6. I would like to install an Offy 2x1 intake using two stock Carters . Any suggestions for modifying the auto choke linkage? Should I convert to an electric choke?
Thanks for your input.
PostPosted: Fri Oct 28, 2005 10:26 am
Several options exist.
You can make a new choke shaft that extends all the way through both carburetors, starting with a stock 225 pushrod. Watch out for the accelerator pump, though.
Or, see this Thread on the topic.
And yes, I would use an electric choke kit number 1234 from CarbsOnly.
PostPosted: Fri Oct 28, 2005 11:24 am
Thanks SlantSixDan!
That is pretty close to what I had in mind.
Thanks for the info on the electric choke.
PostPosted: Fri Oct 28, 2005 11:26 am
woah thats cool i'll have to keep that in mind :)
Cuda Progress :D
The dart as it sits now :(
