Choke Linkage Modification - Any Suggestions?
https://slantsix.org/forum/viewtopic.php?t=14842
Author:  60 Pioneer [ Fri Oct 28, 2005 9:46 am ]
Post subject:  Choke Linkage Modification - Any Suggestions?
I am a newbie starting to work on a '60 /6. I would like to install an Offy 2x1 intake using two stock Carters . Any suggestions for modifying the auto choke linkage? Should I convert to an electric choke?
Thanks for your input.
Author:  SlantSixDan [ Fri Oct 28, 2005 10:26 am ]
Several options exist.
You can make a new choke shaft that extends all the way through both carburetors, starting with a stock 225 pushrod. Watch out for the accelerator pump, though.
Or, see this Thread on the topic.
And yes, I would use an electric choke kit number 1234 from CarbsOnly.
Author:  60 Pioneer [ Fri Oct 28, 2005 11:24 am ]
Thanks SlantSixDan!
That is pretty close to what I had in mind.
Thanks for the info on the electric choke.
Author:  1966 dart wagon [ Fri Oct 28, 2005 11:26 am ]
woah thats cool i'll have to keep that in mind :)
