| Carb adjusting => it rattles when i push full throttle https://slantsix.org/forum/viewtopic.php?t=14843 |
| Author: | marc426 [ Fri Oct 28, 2005 10:27 am ] |
| Post subject: | Carb adjusting => it rattles when i push full throttle |
Hello everyone, been stuck all afternoon after that damn carb adjusting!! I've got a kinda smooth idle maybe a bit high but still... When i'm at idle and i push the pedal all the way to the floor (on neutral), it will choke unless i make it first half throttle then full (well i think everybody understands me). Another important thing! It does make this only if i lower my idle. If it is higher than normal (just a bit) it just accelerates fine! I also didn't adjust my spark advance. Should i do it first? What value should i set static? I don't have any tools to adjust it so i'll try to make it by ear but never made it before! Thanks for your help Marc P.S : figure time! : my dart is a 68 with a 170 and a holley 1920 |
| Author: | Rust collector [ Fri Oct 28, 2005 11:07 am ] |
I believe the carb is the last thing to adjust. Try the ign timing at 5-10 degrees first... |
