Delete ESC...Which Wires to Tap Into???
https://slantsix.org/forum/viewtopic.php?t=14848
Author:  Mooosman [ Fri Oct 28, 2005 9:07 pm ]
Post subject:  Delete ESC...Which Wires to Tap Into???
Hi guys, been a while since I posted here. I was between slant-powered stuff for a while after selling my 61 Valiant, but I'm back into it now with my newest toy!
It's a 1981 Dodge D150 long bed, 225 slant, 727 auto, 3.21 gears. This thing is actually pretty peppy around town for what it is, but there are still some things that need going through.
I want to delete the ESC computer on the air cleaner and convert to the regular Chrysler electronic ignition, but I don't know which wires to tap to do it. I already have the MP wiring harness, the module, a distributor, a ballast resistor, and a coil. I need to know which wires to tap for the power to the module. I know it's probably one of the wires that plugs into the ESC thing, but which one?
Any help or diagrams would be helpful. Pics too!
Thanks guys
Nick
Author:  Super6 [ Tue Nov 01, 2005 11:14 am ]
The wire you need (ignition switched 12 volts) will be either red or dark blue. The easiest way to locate it is too look at the two wires coming off your voltage regulator (up and slightly to the passenger side of the valve cover on the firewall). One of the two wires will be green, the other either red or dark blue. That is your ignition switched 12 volt wire. Standard EI usually uses two ignition switched wires, one that has power with the key in the 'start' position, one with power when the key is in the 'run' position. The wire you found above has power with the key in both 'run' and 'start'.
FWIW - if your ESC is working properly, and the truck is running well, why convert to standard EI?
-S/6
Author:  Mooosman [ Thu Nov 03, 2005 5:11 am ]
Normally I would agree with you about leaving the ESC in place, but it isn't working like it's intended; at idle, the timing varies, and the truck will sometimes die when coming to a stop when cold. Overall, I think the system is fine when all the components are in good shape. But when the computer is mounted to a hot, shaking engine for 25 years, it takes its toll on electronics!
So, I'm just going to throw the standard Chrysler EI on there, and GO!
Nick
