It is currently Tue Nov 17, 2026 9:04 pm
 Post subject: Engine Dies
PostPosted: Tue Nov 01, 2005 9:40 am
SSRN National Champion
Need help with a 72 plymouth skamp slant 6. The motor will crank and idle just fine when you first crank her but after driving the car around the block and warming it up it will not idle and dies when you come to a stop. Any ideas on what the problem is. thanks norm
PostPosted: Tue Nov 01, 2005 10:19 am
Norm,
Sounds like either tight valves, or reversed leads on the electronic distributor. Try adjusting the valves again and that will probably be it.
Otherwise, could be lots of things, like carb idle mixture or vac leak.
PostPosted: Tue Nov 01, 2005 10:24 am
Thanks Lou I will start with adjusting the valves again.
 Post subject: Re: Engine Dies
PostPosted: Tue Nov 01, 2005 1:24 pm
maybe she's just lazy..... :roll:
Juan Ignacio Caino
