It is currently Wed Nov 18, 2026 4:10 am
 Post subject: slant/6 troubles
PostPosted: Fri Oct 28, 2005 8:49 am
Hey everyone, I'm a new member. I am also a member of SLAM-St. Louis Area Mopar's. I have a few problems with my /6, and maybe you all can help out. My 69 Valient really hasn't been running for about 2 years. My brother John was helping me with the issues, but he was in a really bad auto hitting a bike acident, and had some brain damage. So he isn't here to help. Might I add, he does have a sweet 72 Sattilite with a /6. Anyway, I built a super /6 for my Valient. Shaved the head, ported& polished it, valve job, towing/econo cam, double roller timing chain, shaved the block, bored it out +.30, electronic ignition, 2bbl alunimum intake with a 2bbl Carter off of a 80's model Dodge truck, headders, and flowmasters. Compression is 9.1:1. I really don't know anything about carbs, but I rebuilt it. I have tried adjusting it, but it is like it runs to rich. I put a fuel pressure regulator on it, but it runs to rich, or next setting down, not at all. Is the compression to high, and it is sucking fuel past the needle and seat? Do I need to convert to a small 4 bblcarb? To much fuel from the fuel pump? My brother Steve built a /6 also, and he is having the same problem. If someone could give me some ideas, that would be great. I moved not to long ago, so I don't have any of the calculations that I used/ came up with. But I am good with math, and I know that the math is right, and had it checked multiple times. Your help is greatly appreciated.
Alway's remember, 6> or = to 8!
 Post subject: Re: slant/6 troubles
PostPosted: Fri Oct 28, 2005 9:31 am
OK- more info needed. When you say its "like" it runs too rich- exactly what is it doing? Is the problem at idle, or at cruise, or WOT? Is the problem with the engine hot or cold? What is the choke setup like?
When you rebuilt the carb, did you set the float level carefully? Have you tried lowering the float level a little to lean it out? When you say you "tried adjusting it," does that mean just the idle mixture screws, or did you try changing jets, metering rods, or metering rod springs?
Pile on the details, and someone can almost certainly help you out.
 Post subject: /6
PostPosted: Thu Nov 03, 2005 7:54 am
Awsome, I new I could count on you all. Well, all I have done to the carb is adjust the idle mixture screws. It kinda has the smoke coming out the back like a diesel truck, not as thick though. It is when it is hot or cold. I have to keep the gas on to keep it running. Manual hand operated cable choke. It kinda pops through the exhalst? at low and high rpms, parked and driving. kinda like it is missing at about 10 second intervals, but you don't hear it through the carb. The plugs are always carbonized. I have ran regular and premium through it. Now that I am thinking about it, could the distributor be off a tooth also?
PostPosted: Thu Nov 03, 2005 8:13 am
First off, read this if you haven't: http://www.slantsix.org/articles/supersix/article.htm
There are tips on how to adjust your carb.
Here are my thoughts:
(1) sounds like your metering rods are misadjusted.
(2) sounds like you put a v-8 carb on a slant six
(3) sounds like you may have a vacuum leak
At the risk of some controversy I recommend that your get a slant six specific Carter BBD carburetor. There are internal as well as external differences between the v-8 and slant six versions that warrant the exra effort. See here: http://www.slantsix.org/forum/viewtopic ... +different
Is the intake manifold one of the two-piece welded together type? You may need to fill he porous seams with epoxy to eliminate all potential pinhole air leaks.
PostPosted: Thu Nov 03, 2005 8:35 am
I have the same build in my car.....with a V8 BBD. It runs beautifully.
I would make sure your valves are set right (popping exhaust)
I would check timing (new compression ratio)
If it runs rich it probably is not a vacuum leak.
Your compession is not too high.
You will have detonation issues at low rpm with 9:1 CR and a econo cam.
This may lead you to retard your timing too much. (I had to change advance curve to run 9.25:1 CR and 264 cam with a Super 6)
I think the first thing to do is check your float level and choke setting.
