It is currently Wed Nov 18, 2026 11:15 am
 Post subject: flooding carb
PostPosted: Sat Nov 05, 2005 12:47 am
my dad has an 63 dart 270 with a 170 slant but de carb floods when he togue the throttle
its a single bbl carter carb
coude somebody help :!:
PostPosted: Sat Nov 05, 2005 11:48 am
sounds like the needle valve inside the bowl is not closing all the way.
you could try lightly tapping on side of carb with screwdriver handle.
but most likely, the valve needs cleaning . also the float inside
the bowl may be broken or needs adjusting.
