| Truck Hard to start, but then runs great https://slantsix.org/forum/viewtopic.php?t=14857 |
| Author: | nate_o [ Sat Oct 29, 2005 4:21 pm ] |
| Post subject: | Truck Hard to start, but then runs great |
OK I am having a problem with my 81 1/2T W/ a 225. Every morning when I try to start I have to pump the hell out of it and crank forever before she will start. The choke works fine(its been converted to manual) and once its starts it runs great. Lots of power and starts fine the rest of the day. It is a 1 barrel and has the infamous leanburn. What do you think my problem is?? Thanks |
| Author: | SlantSixDan [ Sat Oct 29, 2005 4:30 pm ] |
Get up 15 minutes early Monday morning and before you try to start the truck, try this before you attempt startup: Open the hood, remove the air cleaner lid, and with the choke open, operate the throttle linkage. You should see a good, strong shot of fuel squirting into the centre of the carb. If it's weak and piddly or nonexistent, it indicates your carb is emptying overnight, AND the fuel pump could be losing its prime through some leaky valves. That would cause you to have to drag fuel alllllllllllll the way up from the tank to the pump, then fill the carb, before the engine will start. The Fuel line mod often improves cold starting by eliminating boiling in the line between the carb and pump. I believe 60Seneca has some spares of the fittings necessary for this mod; PM him and maybe he'll sell them to you. While you're reworking the fuel line, you can do the next test in sequence: One morning before trying to start the truck, disconnect the fuel line at the carburetor and put the end of the line in a big coffee can arranged so it can't spill. Disable the ignition (pull the coil wire, for instance) and crank the engine. Take note of how long you have to crank before fuel gushes strongly and consistently out of the fuel line. If it's not immediate, replace the fuel pump. Lean burn: Get riddofit! |
| Author: | nate_o [ Sun Oct 30, 2005 3:19 pm ] |
Dan- Thanks for the reply! I checked the truck today and did not see any squirt in the carb but when I took the line off the fuel pump and cranked it I immediatly got a steady stream. The fuel filter is already on the right side behind the alt. but there is a metal line from the filter to the carb. Do you think this could be the prob?? Thanks again |
| Author: | nate_o [ Wed Nov 02, 2005 11:07 am ] |
| Author: | SlantSixDan [ Wed Nov 02, 2005 11:50 am ] |
OK, so the carb is emptying out overnight, and you're having to fill it up before the truck will start. Some carburetors seem to do this no matter what you try to make 'em stop, but there are some things you can check to make sure they're set correctly. Float setting and bowl vent setting are critical, and you gotta, just gotta have the right (thick insulating) carb-to-manifold gasket to prevent the carb turning into a teakettle and boiling dry. If it's been awhile since you went through the carburetor with a kit, now's probably a good time... |
| Author: | emsvitil [ Wed Nov 02, 2005 12:50 pm ] |
I added an a electrical fuel pump at the tank to prime the system before starting.............. runs about 30 seconds, then leave it off. Dan, yes it's a bandaid, but it works |
| Author: | SlantSixDan [ Wed Nov 02, 2005 1:00 pm ] |
Quote: I added an a electrical fuel pump at the tank to prime the system before starting.............. runs about 30 seconds, then leave it off.
Sure it works, but...wow, that's a lot of work to go to in order to avoid finding and zapping the cause of the problem!Dan, yes it's a bandaid, but it works (our own Doctor Dodge, who is fortunate enough to have compressed air readily available in his garage, made a special fuel cap for one of his infrequently-used cars. It has a tire valve fitting in the middle of it. If it's been a long time since he's used that car, he pops on the special cap, hits the fitting with air pressure to push fuel up to the carb, then takes off the special cap and puts the regular one back on.) |
| Author: | dakight [ Wed Nov 02, 2005 4:25 pm ] |
I guess I don't understand all the chicanery... If you're going to the trouble to put in an electric pump, why not just let it take over? And the gas cap thing, well I'm just speechless and more than a little amused. |
| Author: | emsvitil [ Wed Nov 02, 2005 5:50 pm ] |
Because it's one of those inline electric pumps that's really annoying as it CLICKS along pumping away.................... But it does have a side benefit............ Turn it on to get those last drops of gas out of your tank as you start sputtering............... (got one of those non-working sending units) and then you can sputter into the gas station rather than coast to a stop........... |
| Author: | dakight [ Thu Nov 03, 2005 3:20 am ] |
Well, you could always mount it on rubber isolators to muffle the click. I've only used an electric pump once but I didn't notice the clicking when I was actually driving. I could hear it when idling, espcially if the door was open but never when actually in motion. It was on an '82 Reliant K with a 2.2. The thing had an insatiable appetite for fuel pumps; I think I put 3 in it before I finally gave up and went electric. That solved the vapor-lock problems I had after moving to Denver too. |
| Author: | Slant6Ram [ Thu Nov 03, 2005 3:43 pm ] |
| Post subject: | More tips |
A thicker gasket under the carb was a good suggestion, and finding the leak in the carb is another big step in the right direction. You could also try switching to a Holley 1920, they are simple. Another tip is that old spark plugs don't start as well as new ones. They are a cheap item and can make a big difference in starting. Champion sells good hot plugs for slant sixes. Some other brands really don't fly in these motors. |
| Author: | Slant6Ram [ Thu Nov 03, 2005 3:48 pm ] |
| Post subject: | About lean burn |
One more thing, If you've got lean burn, your distributor may have the dual pickup design. If it does, one of the pickups is for start, the other is run. If the start pickup is dead or failing, it could be causing a lot of trouble. A factory service manual should give diagnostic instructions, but you could start by cleaning and inspecting the connections to the distributor. Lean burn can be a real pain at times. |
| Author: | SlantSixDan [ Thu Nov 03, 2005 4:10 pm ] |
| Post subject: | Re: About lean burn |
Quote: Lean burn can be a real pain at times.
Yep. I find Lean Burn is a real pain except in one situation: When it's at the bottom of a garbage can. Then it causes happy feelings!
| Author: | nate_o [ Sat Nov 05, 2005 4:20 pm ] |
Thanks guys, I suspected the carb but wanted a second opinion from someone with a little more knowledge then me. I guess its time to switch to the 2 barrel manifold and carter carb. I have all the parts I just have been afraid to do it because the 1 brl man. on there now is aluminum so the mounting studs are VERY rusty. I know they are going to snap when I take them loose. |
