It is currently Wed Nov 18, 2026 12:16 am
 Post subject: speedometer
PostPosted: Sun Aug 21, 2005 1:34 pm
my speedometer swings back and forth like a drunk single woman on a cruise ship dance floor.
one of these days i will pull the cable and grease it with white lithium but it lead me to think, could i put in a tachometer and then by looking at my rpms and knowing what gear i am in (3 speed automatic, 75 dart custom) determine my speed? or would that require a bunch of difficult calculations based on wheel size and gearing and such?
 Post subject: bell sound
PostPosted: Sun Aug 21, 2005 1:42 pm
also, when i accelerate [and only when i am in drive, it doesn't work if i push the gas in park] there is a sound like the bell of an old alarm clock, slightly dampened. the bell rings faster the faster i go. its not always there, but it usually is. i kind of like it, one of those endearing car quirks, but the sound comes from the general direction of the speedometer. could that be the source?
PostPosted: Sun Aug 21, 2005 2:27 pm
Put tons of lube on the cable when you do it, don't be stingy. May not help in your situation though with the noise.
That noise your hearing is the speedometer. The needle is attached to a mechanism that holds a small aluminum cup. The speedo cable is attached to an arm with small magnets on the end. The arm is nested within the aluminum cup, and when it is spun by the speedo cable, the magnetic fields move the aluminum cup moving the needle. If the bushing that binds the arm to the cable wears out, then the arm will rub the aluminum cup and make the noise your talking about. Eventually when the arm gets good contact with the cup, it will swing the needle to the far right, peg it and probably break it.
RPM can't be used to figure speed directly. Well, I take that back, it can, with no load on the engine on flat ground, but if your going up a hill or even a slight incline the calculations will be off. If you drive up a hill at say 2000 rpm, your not going the same speed as driving down a flat road at 2000 rpm. May be possible to rig a map sensor into the mix to judge engine load but this is getting way too complex, your better off getting a known good speedo or geting yours rebuilt.
 Post subject: Re: bell sound
PostPosted: Sun Aug 21, 2005 2:51 pm
Ting! Ting! Ting! Ting! That's the shoes grazing the cup on the backside of your speedo, indicating the speedo head bearing is sloppy. When it gets a little sloppier, the shoes will hang up on the cup and fling it hard against the top stop. This usually wrecks the speedo head so it can't be rebuilt successfully.
Time for a speedo head rebuild. This is just one of those things that wears out and needs rebuilding when you drive a 3- or 4-decade-old car. Fix it once and you're good to go for another three or four decades. And it's REALLY nice not to have the speedo needle jumping around and quivering all the time!
DeLuxe Speedometer and Radio
1410 Speer Blvd
Denver, CO, 80204
(303-629-6958)
Did a fantastic job rebuilding my '62 Lancer speedo, and they've done likewise excellent work on several friends' old Mopar speedos since that time.
You're looking at $85 to $100 for the rebuild.
PostPosted: Sun Aug 21, 2005 2:56 pm
thanks for the input. is there anything i should know before i remove the instrument panel and pull the speedo? i imagine there are a lot of delicate parts back there.
also, is it cheaper to put in an aftermarket speedo?
PostPosted: Sun Aug 21, 2005 3:06 pm
There is no direct replcament aftermarket speedo. If you want to put aftermarket speedo in the same place on the dash you either need to cut up the dash to mount it right or build a new dashboard. There are also a couple companies that sell blank dashboard bezels and you can drill it out for whatever gauges you want.
Otherwise if you want to mount it somehwere else you'll need a longer speedo cable.
You can always go to an electronic speedo, that come with sensors to mount on the cable, then you run the wires wherever you want to put the speedo.
I was in your shoes recently and considering all the options, paying for the speedo rebuild is the least amount of headache.
Reach under the dash and try to tweak the angle of the cable, that may or may not alleviate the sound temporarily.
PostPosted: Sun Aug 21, 2005 7:01 pm
Not really. Disconnect the battery first. Reach up under the dash and disconnect the speedometer cable from the back of the speedo. On your '75 it'll either be a plastic squeeze clip to release it, or a metal thumb nut to unscrew, then just pull it off. Also, find the headlamp switch behind the dashboard. Tape a penny to your index finger or thumb and use it to push the rounded release button on the side or bottom of the switch assembly with the one hand while you firmly pull the headlamp switch knob with the other -- the whole knob and stem will come out, letting you remove the instrument cluster faceplate.
This is one of those times when that factory service manual I recommended could help you out with procedures!
Be sure to package up your speedo carefully when you send it off.
By the time you buy and mount a decent-quality aftermarket speedo? No, it won't be cheaper. And it'll look hosey, too.
PostPosted: Sun Oct 30, 2005 11:05 am
hey dan, tried last weekend to remove my instrument panel. releasing speedo clip no problem. ditto with headlight switch. however, the column of the steering wheel keeps me from being able to pull the instrument panel.
the gear selection unit is what is in the way. any suggestions?
also, on the factory service manual, where is the best place to find it, ebay? just search for dodge dart facotry service manual?
thank you
matthew
God took you away, then brought you back to me.
PostPosted: Sun Oct 30, 2005 12:31 pm
You need to lower the steering column enough to tilt the cluster out. Remove the 2 or 3 boltsw holding the support bracket and push down on the column enough to remove the cluster. FSM outlines these procedures.
47 Dodge Custom 4 Door sedan
87 D100 Short Bed slant 6
Retired USAF 1966-1986
PostPosted: Mon Oct 31, 2005 3:43 pm
For the Factory Service Manual, you can try e-bay, local swap meets or used book stores (this might be a stretch but you may get lucky), there are also several online places to purchase cd-rom versions of these manuals. I have picked up several 72 and 73 FSM's from Swap Meets. I got a 72 manual from e-bay for $25, a lot cheaper than the cd-rom. I personally prefer the books because you can have them out in garage/driveway while you are doing the work. Its all about right place right time on the price of these those.
http://cgi.ebay.com/ebaymotors/1975-Chr ... dZViewItem this is 75 manual on e-bay for a decent starting price and the auction ends today.
 Post subject: factory service manual
PostPosted: Tue Nov 01, 2005 4:45 pm
I took a look on Ebay, what is the difference between the body service manual and the chasis service manual?
PostPosted: Tue Nov 01, 2005 5:19 pm
You need both books. One covers the mechanical stuff, the other covers the body, trim, etc.
