It is currently Wed Nov 18, 2026 12:33 am
PostPosted: Mon Oct 31, 2005 2:47 pm
OK. I would imagine that this has been discussed before, but being new to this forum, I'll ask.
I'm putting dual stock 1bbl carbs with an Offy intake on my '60 /6. I know that I will have to modify or re-fab the original throttle torque shaft, but will I have to modify or re-adjust the trans kickdown if I don't touch it?
Thanks for all the info that everyone provides. I've learned a lot by going back through some of the past forums.
Bill
PostPosted: Mon Oct 31, 2005 3:47 pm
Naw, it's pretty easy to work with the 2x1 on a car with the rotating-rod throttle linkage. Since the trans kickdown comes off the rotating throttle rod just ahead of the firewall via a bellcrank, it will be minimally affected by the changes that take place out at the manifold end of the throttle rod.
PostPosted: Mon Oct 31, 2005 7:54 pm
I'm working at a new linkage for that manifold, one that allows me to use the cable type 1920 economasters sitting ontop that mani, or even any other carb that I feel like using... and coaxial manual choke linkage, and cable type kickdown, operated by a short cable (like 7 or 8"). I'll post my results and progress as soon as I have any :lol:
Juan Ignacio Caino
PostPosted: Mon Oct 31, 2005 8:19 pm
The existing 2x1 linkage kit does use the cable-type carb lever.
Please do, sounds useful and nifty!
PostPosted: Tue Nov 01, 2005 7:12 am
See how things are diffrent? down here, we ain't have any aftermarket suplliers like offy or clifford. This manifold was factory OEM carburetion equipment for our '65 valiant GT, and used 2 holley 1922, wich had the typical rod linkage (by that era, we didn't have any cable operated throttle linkage....)
It might take some time since I'm doing it squeezing some time off my other "serious" work. But I'm on to it, since I wanna install them so bad.... I'm literally dying for using them dual 1 barrels.
Juan Ignacio Caino
PostPosted: Tue Nov 01, 2005 9:01 am
AHA! You've just solved a big mystery for me. I have a 1966 Argentine Dodge Dart brochure, and it shows a small picture of the engine compartment with 2x1bbl, and I was thinking "Uhmmm...what's an aftermarket manifold doing in a factory brochure?".
This manifold was aluminum, iron...?
PostPosted: Tue Nov 01, 2005 9:08 am
Thanks again, SlantSixDan!
PostPosted: Tue Nov 01, 2005 1:36 pm
hehe... yeah, we got our Valiant III GT and some of the early production of the Valiant IV GT (that would be dart '63 and dart '65 respectively compared to american production) with that manifold. Excellent combo that made the slant very happy. By that time, they was uing 8:1 nominal CR. That engine did put out 180hp at the dyno, making it the most powerfull mill that our local branch ever produced. Years later, when they came up with the Holley 2300 equipped dodge polara RT (the engine I have in my car) that same mill but with 8,5:1 CR and shorter throw (4") put out 175 HP. The dual 1 bbl manifold was sand cast aluminum, pretty much like the offy intake, but has stronger flange on the head/mani side. Is has a built in balance passage into wich taps the PCV valvle, and the brake booster taps into the #6 runner as usual.
One question I always asked to myself is why the slant manifolds (at least the ones I've seen down here) are slanted towards the front of the engine (making the fuel bowl lower than the back of the carb) for about 5 degrees. In this dual mani the back carb has a slightly larger plenum due to this thing. And the throttle rod linkage attachment on the mani are the same: the back one is taller. Keeps up with the other angle, though.
Juan Ignacio Caino
PostPosted: Tue Nov 01, 2005 1:43 pm
Yeah, that's it, it's a Valiant IV brochure. That manifold easier or harder to find than a Penìn unit?
Shorter throw what huh???
That's 'cause the engine is installed with about a 5 degree slant towards the back! So, the carb sits level when the manifold is on the engine.
PostPosted: Tue Nov 01, 2005 6:44 pm
Easier cuz they never allow the use of this dual 1 barrels manifold in racing categories. I have one complete and one w/o linkage. Not a cheap find, though, I paid AR$ 300 for the bare one and AR$ 450 for the other. (The linkage wasn't much of a diffrence, but the more expensive one is a penin reworked unit. All tuned inside and mirror polished and surface treated on the outside (burnished with special hard steel tool for compressing up the metal on the outside, creating a porous-proof exterior). I have found a penin unit in a racing shop, hanging on the wall. The guy doesn't wanna sell it to me... I'm trying to get him to let me copy that unit at some reputable aluminium foundry.... will see... but old racers are cranky down here... :lol: I hope this ain't end like the nice '70ish aluminium head tale that you told me :cry: I'll hate to see that happen.
Shorter STROKE, me moron spanishpeaking @$$#&!%.... :lol:
Duh... I did think that this alternator is giving me a hard time.... dup duuuh boohboup.... :roll: :wink:
Juan Ignacio Caino
Users browsing this forum: Amazon [Bot], Bing [Bot], Google [Bot] and 7 guests
