78 Aspen Super six
https://slantsix.org/forum/viewtopic.php?t=14881
Author:  bbbbbb9 [ Tue Nov 01, 2005 6:28 am ]
Post subject:  78 Aspen Super six
Failed emmision because of Carbon Monoxide. Hydrocarbons were low.
I'll admit I put some of that "Fuel system" cleaner in about a third of a tank of gas. (dumb) and ran it through. Would that be it?
Any help would be appreciated.
Author:  70valiant [ Tue Nov 01, 2005 10:35 am ]
High CO readings indicate a non working catalytic converter
Author:  SlantSixDan [ Tue Nov 01, 2005 10:45 am ]
Could be a faulty catalytic converter. Could also be a great many other things, from a faulty air injection system to a dirty air filter or plugged air bleeds in the carburetor. I don't think the fuel system cleaner you put in is the cause. Can you post your full test results for us to take a look at?
Author:  dakight [ Tue Nov 01, 2005 1:17 pm ]
I had an 85 Dodge pickup with a 318, that I bought in Oklahoma where there were no emissions tests. When I moved to Colorado it wouldn't pass because of high CO levels. I suspected the catalytic converter because the nozzle restrictor had been chiseled out; of course the only reason to do that is to run leaded fuel. I took the truck to a muffler shop where they cut the tailpipe loose and looked at the converter. They told me it was fine, though I'm still not convinced to this day. I ended up putting smaller jets in the carburetor to get it to pass. That probably has no bearing on this problem, but it reminded me...
Author:  SlantSixDan [ Tue Nov 01, 2005 1:45 pm ]
Very common when moving a non-High-Altitude-Certified, carbureted vehicle to high altitude. Less Oxygen-dense air = richer mixture = more HC and CO in the exhaust. You did the right thing by jetting down the carburetor. As far as your exhaust shop, I'm not sure what they thought they were looking for. Those who misfuelled their unleaded vehicles with leaded fuel usually didn't bother gutting the catalyst, they just let it die from leaded gas.
Author:  dakight [ Tue Nov 01, 2005 3:50 pm ]
That was kind of my take on it too.
Author:  bbbbbb9 [ Wed Nov 02, 2005 5:34 am ]
Ok, here are the readings.
Pollutant 1st Idle Precon Final Standard
Hydros 129 136 154 250 Pass
CO 2.97 3.18 3.38 2.00 Fail
The last time it was passed was 2000
But it flew through
It fired right up and runs great!
Help!
I was just going to pull the engine for a project but with gas the way it is, I'd like to take advantage of the OD tranny!
Author:  SlantSixDan [ Wed Nov 02, 2005 7:43 am ]
Your hydrocarbons look OK, not super-great but certainly OK. Your CO, yeah, is out of line. What's been done on the car recently? How long since a careful tuneup?
Author:  Jeb [ Wed Nov 02, 2005 8:42 am ]
When was the last time you checked your timing?
Author:  bbbbbb9 [ Wed Nov 02, 2005 10:06 am ]
Quite a while!
That's this weekend.
You only get 2 Fails and then it kicks it to another level and I don't want to pay Joe's Garage to make it pass before I talked to you, Very Intelligent Car Geniuses
Author:  slafolle [ Wed Nov 02, 2005 10:08 am ]
High CO usually indicates a rich condition. I'd start with the carburetor: check that the choke works properly, float adjusted OK, air filter not clogged (as Dan suggested), etc.
You can ask the smog guys about a pre-test (unofficial test where the results are not reported to the state) to check your repairs before the official test, to help avoid being bumped to the next level.
Steve
Author:  bbbbbb9 [ Wed Nov 02, 2005 10:18 am ]
Steve
I'll check into that.
I'm in AZ BTW.
Thanks
