It is currently Wed Nov 18, 2026 6:38 am
 Post subject: Broken engine mount
PostPosted: Wed Nov 02, 2005 10:36 am
My drivers side engine mount broke the other day. My question is simply where is the best place to buy a new one for a '65 Dart. I bought this one a couple years ago and it obviously didn't last too long. Thanks for the input.
PostPosted: Wed Nov 02, 2005 11:07 am
Insulator or the metal mount? I personally would expect the pass side to fail first since they get coated in oil from leaking valvecover gastkets. I'm just joking since there isn't any real torque against the pass just compression forces they aren't really failure prone. By any chance do you remember the brand name of the mount you bought and please say you didn't get it from dangerzone. Get one from napa or carquest.
PostPosted: Wed Nov 02, 2005 2:38 pm
The insulator broke, right at the top, it appears that the metal bolt pulled through the rubber. I'm trying to remember where I bought it, I'm fairly sure it was a Parts Plus unit. The other side is NOS. Should I try my luck again with the Carquest unit or go elsewhere.
PostPosted: Wed Nov 02, 2005 4:27 pm
You might have trouble getting the mount from a normal part store. NAPA catalog is wrong. It shows the mount as 66-69. It should show as 67-69. I don't think carquest, even has a listing any longer. The last set of mounts I got, were form The Paddock, about 6 months ago.
PostPosted: Wed Nov 02, 2005 6:52 pm
You might try Espo Springs&Things.(www.espo.com.) They ship pretty fast. Got my '64 Dart Mtr.Mounts, Rear Springs, & Front end components from them. Your better off calling them since they don't list a whole lot on the website.
PostPosted: Thu Nov 03, 2005 12:22 am
Go to napa and ask to look through their books with the pictures of the mounts. Thats how I found my driver side mount (listed wrong), and found out they had a dozen passenger side mounts (of course, listed wrong. Bood called for a passenger side mount for a C body slant of all things). Ancher also makes mounts, you can usually find them at some of the local, independent parts stores (where I found my passenger side mount, after telling them the part in the book was wrong). Unfortunatly, you have to do some leg work to find certain parts.
PostPosted: Thu Nov 03, 2005 7:11 am
I just called the Paddock. They have both, left and right mount in stock.
EM 2303 and EM2304. $17.95 ea. phone 1-800-428-4319
PostPosted: Thu Nov 03, 2005 1:33 pm
Thanks for all the thoughts and reference numbers, I'll work on buying it in a couple days.
PostPosted: Thu Nov 03, 2005 4:27 pm
I wouldn't wait too long. When I called, they had 2 of one side and one of the other, in stock.
Users browsing this forum: Amazon [Bot], Bing [Bot] and 4 guests
