Trying to understand idle speed
https://slantsix.org/forum/viewtopic.php?t=14901
Author:  75dartcustom [ Wed Nov 02, 2005 9:22 pm ]
Post subject:  Trying to understand idle speed
I am trying to understand idle speed, as my car likes to die in the cold mornings now. I have read the choke adjustment aritcle posted here once but it will probably be a few more readings combined with some hands on before I really understand it.
I am confused as to why an engine idles faster in park and neutral than it does in reverse or drive.
Also, why is idling bad for an engine?
An engine needs more gasoline when it is cold, i think, and as it warms up needs less.
My car starts like a champ when cold. Fast idle cam works great, she revs up to 1500 as soon as I crank the engine. Choke is closed when engine is cold, correct, and then opens more and more as it warms?
However, for some reason, even though she runs great in park when it is cold in the morning, as soon as i shift into gear she wants to stall. Someone has recommended that i shift into neutral as i approach stop signs to preclude stalling. So does this mean my choke is opening too much too quickly in the cold?
Second, I have the issue with warm start, which I am sure some of you are sick of hearing about. However, my mother taught me to be dogged in my pursuit of understanding. So I press on. I have to give the car a lot of gas at warm start. Which leads me to believe that again the choke is opening too much when the car has not had time to cool all the way back down before I start her up again. So to solve both problems I have to dial the choke back so it stays closed more in certain situations. Am I correct in these assumptions?
I read in one article tonight, i think the super six, that one way of tuning a car is to hook up a vaccuum guage and tune to acheive maximum vaccuum. This makes sense. Can others corroborate? Can I find a standard vaccuum guage at AutoZone or Advance? Will the included instructions be sufficient for operation of said device?
Thanks guys, for finally giving me an online community to be a part of.
75dartcustom signing off
Author:  VDART [ Thu Nov 03, 2005 5:31 am ]
! can't believe GA is cold!--
anyhow your tranny also needs to warm up-- most likely once you've driven a few miles it doesn't have this problem--
idle & park do not engage the tranny
2 Dan has an article on the warm start problem-- I'm assuming that your fuel line is routed the factory way - metal line next to the engine from fuel pump to carb- route this line over the valve cover-- use good quality fuel line
3-- vacuum gauge is good it allows you to smooth out your idle usually raises the idle-- some guys use it to adjust valves also-- also use the gauge-- to diagnos other engine functions-- they usually come with a sheet giving you tips & pics for your assistance
Author:  SlantSixDan [ Thu Nov 03, 2005 2:29 pm ]
Post subject:  Re: Trying to understand idle speed
Are you still running a Holley 1945 carburetor? If so...you will be a great deal happier and less frustrated if you will replace it with something better. A Carter BBS or a Holley 1920.
Because in a driving range (in either direction), the clutches and bands inside the transmission are applied, ready to transmit the engine's power through to the rear axles and from there to the wheels. Because the car is stopped when it's idling, this readiness-to-drive condition puts a load on the engine. If you were to lift up the rear wheels and then check the difference between Park/Neutral idle and Drive/Reverse idle, you'd find that the idle speed would dip as soon as you shifted out of Park or Neutral, then, as the rear wheels picked up speed, the engine idle would come back up very close to its Park/Neutral range.
Well...that's kind of an open-ended question. Can you be more specific? Where did you hear or read that this is true? Under what conditions?
Sort of. The main reason why there is a choke is that all the metal between the carburetor nozzle and the cylinder is *cold*. As the fuel-air mixture travels past all this cold metal, the fuel tends to condense on the cold surfaces, so by the time the intake charge reaches the cylinder, it contains not enough fuel to support combustion. So, we richen the mixture (with the choke) to provide an oversupply of fuel at the front end of the system (carburetor) so even with condensation, by the time the intake charge reaches the cylinder there's still enough fuel in it to support combustion.
That's rather on the high side.
Correct.
OK, so the choke isn't closing quite enough, or the choke pull-off is pulling off too much, or...you have a Holley 1945 carburetor.
How about if we get the car running correctly so that it doesn't stall? Then this kind of tapdance trick won't be necessary.
Your mother was right. As soon as you possibly can, go buy and read three books: A factory(!) service manual for your '75, which is a 2-volume set, a Stockel book and the Petersen book discussed in this thread here. Worth more than their weight in gold.
And then, give in to peer pressure and dump the Holley 1945! ;-)
Now, does this mean you're pumping the accelerator a lot while trying to start it? Or does it mean you have to hold the accelerator down before it will start? The cause is almost certainly what is called "heat soak", which is when the engine compartment heats up after shutdown (no more coolant circulation or fanned air through the engine bay!). All this rising heat boils the fuel line and the carburetor ("percolation", it's called), which causes a great deal of gasoline to pool into the intake manifold *and* the carburetor and fuel line to empty of fuel. So when you go to start it, you've got to clear out all this excess fuel AND fill the carburetor before the engine will start. Do the Fuel line mod to alleviate these hot-start problems. And get a better carburetor!
No. The choke does not re-close until the engine cools down to near full-cold temperature. If you're having hot-start problems, the only way the choke could be involved is by being stuck partially closed.
That's one way to do it. It's perfectly reliable in cars made before about 1972, in the North American market. Newer than that, and the modifications made for emission control render this method largely useless. A much better way of tuning is with the use of a glass spark plug, marketed under the name "Gunson Colortune". The link goes to Eastwood's product page, but you can probably find one less expensively on eBay. The glass plug gets installed in place of one of the regular spark plugs, allowing you to see the colour of the combustion flame. Too yellow = too rich. Too blue = too lean. You adjust for a nice sort of "gas stove blue". Multiple colortune plugs can be used to look at cylinder-to-cylinder mixture balance.
That said, you're really not quite at the tuning stage yet; you've still got repairs to make.
Author:  SlantSixDan [ Thu Nov 03, 2005 2:32 pm ]
Er...yeah, I was having trouble with that one, too. But, cold is a relative term. Up here in the great white North, we work on our cars in shirtsleeves when the temperature gets all the way up to freezing, and—to borrow a clever phrase from an author I knew—when it's not all the way up to freezing, it feels like god is trying to invent the reverse-microwave-oven all over us.
Errrrr....tilt?
Sure, the trans needs to warm up, but that's not what's causing his stalling, which is entirely related to the fuel system, with maybe a little "help" from the ignition system. Did I misunderstand what you wrote?
Author:  Slant6Ram [ Thu Nov 03, 2005 4:10 pm ]
Post subject:  Idle problems
First,
It's normal to have to hold the gas pedal 1/2 way to the floor when hot starting. My Scamp actually has those instructions on the visor. If it's worse than that, you may have boil over problems which have been explained.
When I have fixed slant sixes which had problems holding an Idle, it has been one of the following problems.
Carb adjustment, but usually you've already tried this by the time you reach this website.
Ignitions system failure such as spark plugs or plug wires or distributor cap or rotor. All of these items should be changed every couple years, so do it now if you haven't already. 'Reading" spark plugs can be extremely useful. As you remove each plug, take careful note of it's condition and color. I recently found a bad (but almost new) plug wire when I pulled the spark plugs and found one which as brown instead of white like the rest. Replaced one wire and the car runs great.
Vacuum leaks will cause a fast but weak idle. The procedure for checking for leaks is explained in great detail in several old posts. I don't have time right now to explain it again.
EGR and PCV valves should be checked for proper operation.
Another problem which is VERY common is burnt or incorrectly adjusted valves. Even the heads with hardened valve seats (after 1973) will burn valves eventually. (I just had one rebuilt for that reason) Valve leakage will make an engine very weak and hard to keep a good idle. Try doing a valve adjustment and keep a close eye out for valves which are too tight. The procedure has also been explained several times if you search for my name.
Good luck, none of these are very expensive to repair. The trick is finding the problem.
Author:  75dartcustom [ Thu Nov 03, 2005 5:26 pm ]
Ok, so first things first, find a replacement carb. And judging by the number of times I have heard that when a 1920 decides to go there is no way to convince it otherwise, I will look for a Carter BBS. I will check ebay, the parts section on slantsix.org, where else should I look?
Will the BBS fit onto my existing intake manifold? Will I have any trouble with vacuum hoses/linkage, etc?
Once I find the Carter I will send it to the carb doctor to be rebuilt. I will purchase the colortune plug, which I saw in Eastwood. However I wondered whether or not it was helpful or just a gimmick Now I know. When I have the new carb I will then reroute the fuel line, hook up the carb and properly tune the engine. Then I will smile, because it breaks my heart to see this beautiful car laboring under the weight of my ignorance. Until I can accomplish all this I guess I just struggle along with the 1945. I am going to find a use for that thing when I $h!tc@n it.
Recommendation for fast idle I read in Haynes and Chilton is 1500 RPM. Is this not correct?
And I have Petersons and Stockel and need to reread some sections, Factory Service Manuals have both been purchased on ebay and are on their way.
How do I check the EGR valve for proper function? And the check on the PCV is to shake the valve to ascertain that the ball can move freely, correct?
When I checked my plugs last weekend all were black with carbon. I had just completed the Super Mario brothers Special with BG44K and water in the carb to clean out the carbon. But the one thing that scared me is I saw oily deposits on plug no. 6. This means I have oil getting past my piston rings, correct? Is this what is called "blow by?"
I also saw light gray smoke coming out my tailpipe tonight for the first time. It wasn't thick, but there was plenty of it. What does this tell me?
Thank you all for your detailed replies. I feel much more clear on a number of things now. I can't wait to be in a position to answer these questions for someone else.
Author:  75dartcustom [ Thu Nov 03, 2005 5:31 pm ]
And you're right, cold is a relative term. You won't hear me complaining, but the 1945 must have been hecho en mexico, because anything below 45 and she gets pissy. Juan, how 'bout I send her down to you? Maybe if shes upside down on the other side of the world that will straighten her out.
Author:  SlantSixDan [ Thu Nov 03, 2005 7:31 pm ]
Well, y'know, one thing you could try for an improvement in driveability would be to open up the existing type 1945 carburetor and see what jet's in it, maybe install one a few sizes larger...
Author:  Bohmer2 [ Thu Nov 03, 2005 8:14 pm ]
Alright, I just picked up two slant six motors from early 1970's cars and I will check this weekend to figure out if either of them has a carter carb on it. One engine is a relatively low mile motor (30K) that still has the 904 connected to it so I think it will probably even have the auto kick down linkage (not sure if the linkage is different for a holley 1945) if it is a bbs and you think you want it I will sell it to you. I can almost guarantee it will need to be rebuilt though because I am sure it has been sitting for some time. It will fit on your existing one-barrel intake.
Second, I posted a link to a 75 factory service manual auction for you once already...check e-bay again.
Brian
Author:  SlantSixDan [ Thu Nov 03, 2005 8:29 pm ]
The BBS will mount right onto the existing intake. The existing throttle linkage will hook right up. Same with the fuel line. Choke will need a rework, get the electric choke kit number 1231 from CarbsOnly.
Which BBS to get? Well, if you're keeping the EGR system operative, then a '73-'74 D100 pickup 225-engine BBS would be needed. Tough to find these. They're available from the remanufacturers, but that's really not a first choice. Better to do as you propose and find a core to send to Georgia for refurbishing.
If you're not keeping the EGR, a '70-'71 (California) '71 (Federal) Dart 198-engine BBS (tag number 4955, 4956) will work, too.
Best way to find cores is by tag number. I don't have these in front of me for '72-'74, maybe Dennis Weaver has 'em.
Author:  75dartcustom [ Thu Nov 03, 2005 10:28 pm ]
What are the benefits to keeping or discarding the EGR?
How can I tell if it still operates properly?
I found a Carter Carb that fits a 71 Dodge truck /6 225 on ebay for $50 rebuilt. The stamp on it is 6025S 3051.
Or I could just search boneyards and do a super six setup. But time is very very limited and I just want a car that runs well.
Also, oil on my no 6 plug. That is oil fouling correct? What can I do to solve this?
Author:  Avenger2040 [ Fri Nov 04, 2005 9:45 am ]
Ok, talking about choke, wich is the common RPM range when choke is working in cold mornings? (Mornings here are about 6-8ºC), cause my choke starts my engine and 1,500 RPMS the goes to 2,200 to 2,400 RPMS.
