| Helo me out here...Timing https://slantsix.org/forum/viewtopic.php?t=14908 |
| Author: | benevolance [ Fri Nov 04, 2005 10:13 am ] |
| Post subject: | Helo me out here...Timing |
Okay, Pulled a rust free Hemi Orange 70 Swinger out of 15 year storage...Motor was stuck...Poured 1 quart of ATF down the carb...One in the valve cover and another down the 6 plug holes...Let it sit for 3 days and then turned it free by hand at the belts... Pulled the gas line at the inner fender hooked up a gas can off the roof to gravity feed...Rebuilt the carb...And lo and behold it fired right up! Sounded perfect...You could not hear it run! 3 hours to remove old oil filter Replaced the U joint...Did the brakes(wheel cylinders, flex hoses)...Fixed all the dried out vacuum hoses and was getting ready to cruise... Then out of the blue I lost fire...So I pulled the dist and replaced the points and condensor...I now have fire but the timing is off... I got help and we popped it up on Number 1...And I stuck a screwdriver in the holr to make sure the piston was at the top...TDC... and that the Mark on the Balancer was accurate...it is! Throw down the distributor...And here is my problem....How can you get it to point at the number 1 cylinder when it is way across the engine... So I decided that I could just drop the distributor in so the small end of the rotor button was pointing at number 3...And wired it from there.... 153624....Placing the number 1 wire where the rotor button was pointing I have fire but it is not timed properly...Tried it three times and it is popping and backfiring so it is definately out of time... There must be something stupid I am doing wrong....someone tell me what it is so I can go cruising! benevolance |
| Author: | Rust collector [ Fri Nov 04, 2005 10:48 am ] |
I think you had the distributor 180 degrees wrong, so I would try to set it back where you had it, and swap the wires "across" the cap. The rotor goes 1 turn every 2 turns of the crank, so I often get it 180 off |
| Author: | benevolance [ Fri Nov 04, 2005 11:49 am ] |
I got it running and went for a drive!!!!! Had a flat tire....I should have known better it was so weather cracked. I was always putting the number one piston at the top...and lining up the mark on the balancer...So I am not sure how I would have gotten messed up with the rotor button turning once for every 2 rotations of the crank...I never looked at the rotor button until I had number one at top dead center. I had this same problem with the last slant I had...Getting it lined up and the distributor exactly on number one cylinder is a pain in the arse... but it is done and it runs like new... Time to install the new carpet and headliner I have for it...The rest of the interior is perfect... Orange car with black guts...Perfect color combo...Maybe next week I can get a new Windshield and have the Vinyl top Replaced. I am just excited to have a swinger that has no rust and shiny paint in the trunk...Thank god it got put away 15 years ago!..Someone was saving it for me! All that is left Mechanically is to replace the ground strap and the battery ends...They are corroded...I want the car to have a proper ground and to make the proper connection. -Benevolance |
| Author: | Eric W [ Fri Nov 04, 2005 12:11 pm ] |
Thats frustrated me many times as well. Glad you got it running! Got any pictures to share? Does the car have hub caps or wheel covers? Sounds like a good time to have black steel rims with dog dish hub caps. |
| Author: | benevolance [ Fri Nov 04, 2005 8:50 pm ] |
The car has Factory Orange Wheels with the Dog Dish hub caps... And I can get you some pictures yes...As soon as I finish getting the interior work finished up... Decided to order a new front windshield rubber and windshield for it tonight...The rubber is hard and the windshield is foggy... I gotta stop spending money on this... |
