valve cover gasket
https://slantsix.org/forum/viewtopic.php?t=14911
Page 1 of 1
Author:  75dartcustom [ Fri Nov 04, 2005 8:15 pm ]
Post subject:  valve cover gasket
I am going to delve into the unknown this weekend, my engine. Its a little scary. I will squirt PB Blaster on the valve cover bolts tonight, then again tommorow to loosen them. Remove valve cover, check valve lash per SSDans instructions in an earlier post, and then replace gasket and re tighten. What do I tighten valve cover bolts to (in ft/lbs)? Is there anything else I should know/do while in here?
Thanks
Matthew
Author:  SlantSixDan [ Fri Nov 04, 2005 8:34 pm ]
I cannot imagine those valve cover bolts needing any kind of penetrant unless someone has been dumping a steady flow of saltwater into your engine bay for a lot of years.
Make sure you get a rubber valve cover gasket; they cause fewer hassles than the cork type, both now and later.
Check the adjustor screws for tightness. If any are loose (noticeably easy to adjust), you'll want to either replace them (the "right" way) or remove the screws and carefully munge the threads slightly with a bench vise or some careful ball-peen hammer taps (don't overdo it) to restore tightness. Otherwise the adjustment won't lash.
Start the engine and make sure you're getting good, even oiling at all 12 rocker arm tips and heels.
And be sure not to get so involved in switching off intake/exhaust/intake/exhaust that you miss the two adjacent intakes in the middle of the engine and get half the adjustment wrong! (I did that my first try...hadda call Doctor Dodge in a blue panic!)
