It is currently Mon Nov 09, 2026 9:30 am
PostPosted: Fri Dec 02, 2005 11:48 am
Car Model: 1962 Lancer 770
I'm considering swapping a 4 speed into my 62 Lancer and wanted to find out if the 63-66 A body pedal assembly will work in my 62. Or am I stuck trying to find a 60-62 assembly from a 3 speed car.
Thanks!
Menko
PostPosted: Fri Dec 02, 2005 12:47 pm
No, the '63-'66 swing pedal assembly won't fit or work in a '60-'62 car.
PostPosted: Sat Dec 03, 2005 11:31 am
on a similar note, anyone know if pedals from a 74 A body will work in a 63-66 A body?
Jay
PostPosted: Sat Dec 03, 2005 11:40 am
Don't believe so, no; you need a '63-'66 swing pedal assembly.
PostPosted: Sat Dec 03, 2005 8:40 pm
that's what I thought. thanks Dan.
Jay
PostPosted: Mon Dec 05, 2005 6:30 am
That depends on how much creativity you put into your linkage, of course. My '66 Dart has the gas pedal from an Aspen, along with its cable throttle linkage. Interestingly, the Aspen brake pedal cover also slipped right over my stock brake pedal.
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
PostPosted: Mon Dec 05, 2005 8:10 am
Well...yeah, but gas pedals are a super-simple swap. We're not talking about gas pedals here, we're talking about clutch-and-brake pedals. Much harder to swap.
