universal
https://slantsix.org/forum/viewtopic.php?t=14922
Page 1 of 1
Author:  75dartcustom [ Sat Nov 05, 2005 6:28 pm ]
Post subject:  universal
how do i check the fluid in my universal joint?
i have a 225 7 1/4 rear end.
also, if i need to re fill it, what is the procedure, can you recommend a lubricant?
Author:  Pierre [ Sat Nov 05, 2005 6:34 pm ]
The fluid level in the rear end, when you remove the drain plug (when facing the rear from back of car, on the right side of the cover, on a 7 1/4 rear) should be just to the bottom of the plug when car is on a level surface.
Standard 80w90 weight gear oil should be fine.
