| leaning out a 318 Carter BBD on a /6 https://slantsix.org/forum/viewtopic.php?t=14924 |
| Author: | textoad1 [ Sat Nov 05, 2005 6:48 pm ] |
| Post subject: | leaning out a 318 Carter BBD on a /6 |
Ok. Got my 74 Scamp running reliably with my rebuilt Carter BBD from a 72 van 318. I need to Pass smog and I can tell by the smell it's a bit rich. I only need to pass an idle test. Any recommendations would be appreciated. My setup is as follows. 225 .040 over bore. Isky cam( mild street, can't remember all the details, I'll dig em up. I think it's the 262) 2 1/4 exhaust, Super six intake and air cleaner, .060 off the deck. Timing set to about 12 BTDC. No EGR. Normal PCV and crank venting. Choke working properly, Valves recently adjusted. Head and block rebuilt and broken in over the past year with about 6000 miles on her. She runs great and strong but smells rich. Last year I passed with the Holley 5200 but I could never get her running right so now I'm running the venerable BBD from a 318. Other than idle mixture, what can I do to get lean enough to pass smog. Also at start up I'm seeing some soot out the pipe. Metering rods, timing, valve lash, isopropol alcohol, low octane fuel. Any advice is appreciated. BTW I have never had the timing over 15 but she never pings FWIW. Thanks in advance. |
| Author: | Reed [ Sat Nov 05, 2005 6:56 pm ] |
I believe that main metering jets for BBDs from the mid 70s and up are interchangeable with those from the more popular Edelbrock Performer Carbs. Double check though, cause i have never done this swap. You should be able to pick up a pair of jets for under $3 at a local speed shop. |
| Author: | textoad1 [ Sun Nov 06, 2005 8:29 pm ] |
I think this Carter pre dates those with the intergchangeable jets. If you are talking about the little stubby brass dudes about 3/8" long, mine doesn't have that style of jet. Any other suggestions would be appreciated. |
| Author: | 73dart_swinger [ Tue Nov 08, 2005 3:26 pm ] |
I can't give you any advice but I know I am in the same boat so I'll be watching this post closely. Any help is appreciated. |
| Author: | mcnoople [ Tue Nov 08, 2005 3:53 pm ] |
You could always create a metered vacuum leak. Run a normal vac hose into the interior put a small valve or pinch it with vise grips and adjust to fix your mix. I had a problem with my valiant when I changed intakes. The new intake didn't have the port for the pcv so to be cheap I simply notched the 3/8" thick gasket to suck manifold vaccum. The car ran rich until I drilled out the intake so it would function properly. So in a roundabout I'm suggesting that you see if the pcv is actually pulling hard vacuum. You can't measure the vacuum it draws with a gauge since it is cfm that matters not inches of vacuum. |
