It is currently Thu Nov 19, 2026 10:05 pm
PostPosted: Sat Nov 05, 2005 5:12 pm
So last night I printed out SS Dan's instructions for valve lash and today I took on the task. A bit nerve racking with your hand moving up and down as you make adjustments, but the most beautiful thing happened:
I did all the exhaust valves first, then started on the intake valves. All valves were loose. I got to the last 2 valves, gave them both a twist to tighten and all of a sudden there was this silence. No more clatter of rockers on valves. I could hardly believe it. I had been so used to that soft clacking I didn't know it wasn't supposed to be there.
However, I do have a problem. After I finished my valve lash I shut off the car, hooked up a timing light with the valve cover still off. Turned her right back on, still warm and adjusted idle speed back to 800 and timing to TDC with the hose to the dist. plugged and the car in park. Her idle was still rough in park. But when I put her in gear the idle was terrible.
I checked the no 1 plug with the timing light to see if it was firing regularly. It fired great in park and great in gear. I then checked the no 6 plug. It fired great in park BUT it missed frequently in gear.
What would cause the no 6 plug to fire well in park but poorly in reverse?
I pulled the no 6 plug and it was black with carbon but showed no signs of wetness or physical damage.
Will the car run poorly in gear until I put the valve cover back on?
I plugged the holes that go to the PCV, oil breather and dist advance on the carb. but the air cleaner was off. Do I need the air cleaner on?
Are you supposed to have the air cleaner on when you adjust idle speed and timing?
I also tried advancing the spark (turning dist. counter clockwise) but that did not help.
Car ran a little rough before the adjustment but nothing like this. And the valves sound much smoother than they used to.
Any help/input is GREATLY appreciated.
God took you away, then brought you back to me.
PostPosted: Sat Nov 05, 2005 5:28 pm
The air cleaner doesn't matter, but the PCV valve does.
The carb is calibrated for the PCV air 'leak'. With it plugged up you're not getting as much air as is expected and are going to be rich.........
PostPosted: Sat Nov 05, 2005 5:34 pm
Does that mean I need to put the valve cover back on and hook up the pcv before I tune (and freak out.) ?
Would running rich really make that no 6 plug fire so terribly when in gear?
PostPosted: Sat Nov 05, 2005 5:44 pm
hook up the pcv valve and hose to the carb.
The pcv valve doesn't need to be in the valve cover and the valve cover doesn't need to be on the engine.................
PostPosted: Sat Nov 05, 2005 5:45 pm
With a bad mixture, anything can happen...........
I'd also check the resistance of the plug wires to see if there's a bad wire.............
PostPosted: Sat Nov 05, 2005 6:04 pm
how do i check the resistance in the plug wires?
plugs are brand new, 50 miles.
plug wires are 3 months old but i have had them fail straight out of the box before.
still, one would assume they would fail equally in park and reverse...
PostPosted: Sun Nov 06, 2005 3:52 am
Even if the plugs are new, if they are black with soot/carbon, the spark can short to ground, instead of jumping the gap. When the car is put in gear, the load on the plug increases. When this happens the spark will travel down the carbon path of the plug, and will not create a large enough magnetic field in the wire to trigger the timing light. Clean the plugs, or install another set of new ones. Make sure the carb in not too rich, or you will foul the new plugs, also. Check the float and choke.
PostPosted: Sun Nov 06, 2005 8:31 pm
You need an ohmmeter (usually it's part of a voltmeter). All the wire should be about the same resistance. Although at 3 months they should be good.
I've had them fail out of the box too. Went back to the auto parts store with the ohmmeter to check the replacement set before I took it home.
PostPosted: Sun Nov 06, 2005 9:41 pm
so after reading your posts it seemed obvious that the fuel fouling was the source of my rough idle. i removed and cleaned the plugs, replaced the valve cover and hooked the pcv valve back up and then dialed the fuel/air mix back 1/4 turn. i started the car with baited breath and vrooom. the smoothest idle my dart has ever had. it was beautiful. thank you all. so many people have talked smack about this car. but the only thing wrong with it is my lack of experience as a mechanic. with your help, she is realizing her full potential and i am showing the rest of the world how beautiful a 75 can be.
