| throttle linkage https://slantsix.org/forum/viewtopic.php?t=14927 |
| Author: | juice [ Sun Nov 06, 2005 10:13 am ] |
| Post subject: | throttle linkage |
okay, rebuilt the carb, old float because the kit didn't come with it, takes six to eight weeks to special order the right one, but tested it and it floats. installed carb and engine started but ran as if i had the pedal mashed, somewhere i went wrong and messed up the linkage, the pedal is at the floor...i imagine no one can really help without looking at it themselves but i thought i'd share and see if i could get any hints or anything hunter |
| Author: | Eric W [ Sun Nov 06, 2005 10:44 am ] |
Did you put the throttle return spring back on? |
| Author: | SlantSixDan [ Sun Nov 06, 2005 10:53 am ] |
Please, when starting a new thread, always state the vehicle make, model, year, transmission type, engine size and carburetor brand and type, as well as any modifications that have been made. Can't really help you until you supply that info; there have been multiple different throttle linkage setups over the years and models. |
| Author: | juice [ Sun Nov 06, 2005 11:34 am ] |
right, sorry, '66 dart 225 holley 1920 single barrel auto trans all stock no mods |
| Author: | SlantSixDan [ Sun Nov 06, 2005 1:37 pm ] |
OK, I'm assuming without factory A/C (with A/C uses a totally different throttle linkage.) Check the throttle return spring, which is situated vertically between the bellcrank just in front of the firewall on the throttle rod, and a little tab bolted to the trans bellhousing. If it's broken or missing, you've found your problem. |
| Author: | juice [ Sun Nov 06, 2005 3:36 pm ] |
my dad got it figured out while i was away and so we got it now (at a loss to my dignity) anyways, thanks for your help and it was factory A/C |
| Author: | SlantSixDan [ Sun Nov 06, 2005 4:46 pm ] |
The '65-'67 factory-AC throttle linkage is very different from the non-AC setup, and can be a little tricky at times. Glad you got it figured out. |
