It is currently Sun May 31, 2026 10:18 pm
PostPosted: Wed Nov 09, 2005 8:30 am
I would like to replace my bench seat in my D-150 truck with some bucket seats. Does anyone have a low cost suggestion that will bolt-up easily. I am looking for either new or something to look for in the junkyard.
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
PostPosted: Wed Nov 09, 2005 10:49 am
Try jc whitney if you don't mind spending the cash for new seats.
PostPosted: Wed Nov 09, 2005 12:05 pm
Contributor
I'm told that mini-van seats are nearly a bolt-in.
PostPosted: Wed Nov 09, 2005 6:15 pm
Buckets from an 81-up ramcharger are a direct bolt in. The low back buckets will fit the truck the best. The high back buckets will rest against the rear window with the seats all the way back.
If you can fabricate mounts, you can fit virtually any bucket seat from any vehicle you want. Just be sure to take careful measurements to make sure they will fit (overall width) beforehand.
-S/6
The "Silver Bullet"
87 Ram D150
